News
Front bonnet on 360 not opening?
Discussion in '360/430' started by traknut, Apr 19, 2009.
  1. traknut
    traknut Karting
    Mar 30, 2006
    121
    The front hood on my 360 will not open with the switch. I checked the fuse, the relay, and the switch, and they are all good. Would it be the mechanism under the hood? Am I missing something else? Thanks
  3. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,008
    Northern California
    Greg Calo
    Under the steering column on the left is a small Tee handle which opens the trunk from the inside.
    At least you should be able to open it mechanically.
  4. traknut
    traknut Karting
    Mar 30, 2006
    121
    I am using that to get into the trunk, but where is the cellnoid? Is it the wrapped cylinder in the brass enclosure?
  5. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,008
    Northern California
    Greg Calo
    You mean solenoid?
    You'll have to remove the front fabric-faced panel to get to it.
  6. traknut
    traknut Karting
    Mar 30, 2006
    121
    Sorry, I spelled it the way it sounds. LOL I have the fabric out already. What do I replace in there? Is it the whole part including the brass box or just what is inside the box? The switch is good because I tried it on the gas door opener and it worked fine.
  8. flipdowt
    flipdowt Karting
    Dec 13, 2008
    204
    Mahopac,New York
    John Flip
    get a volt meter or a test light and see if you are getting voltage to the solenoid.have someone hit the switch when you are set up in the trunk to see if the solenoid is being fed.don't forget to turn the key to the on position
