355 - front bonnet won't release left side | FerrariChat
355 front bonnet won't release left side
Discussion in '348/355' started by rob lay, Jul 19, 2023.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,954
    Southlake, TX
    Rob Lay
    right side won't latch and left side won't unlatch. it is really a hassle because of my side lift I have to enter the car from right side each time to pull handle. when I pull handle there is nothing unlatching.
    thanks.
  2. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    There is an emergency left side release WAY under the left side dash- It's a cable with a finger loop- there is <should be> one for right side as well. It is most likely a lubrication issue with the cables and perhaps the latches- or possibly a broken cable-
    BTW Rob this is not shown in the manual- I had the same issue and embarrassingly took to dealer only for my tech to find the emergency releases for both sides.
    Some WD40 later all was well :cool:
    rob lay likes this.
  3. rob lay
    Dec 1, 2000
    63,954
    Southlake, TX
    Rob Lay
    Thanks a bunch, I'm wondering if the panel or carpet keeping the right side from latching is putting a weird angle on the left one.
  4. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    That could certainly be the case- I would think more along lines of stressed cables and/or wonky latches- For US cars the main release on left actuates both the left release and a cross connect to the right- Not the most optimal design- That's what put me on a search for both emergency releases :cool:
  5. phrogs
    phrogs F1 Veteran
    7,342
    Kzoo Michigan
    Take out carpet and see how it opens and closes.
  6. rob lay
    Dec 1, 2000
    63,954
    Southlake, TX
    Rob Lay
    It was working fine until dealer did a service, they were in there to fix the window washer.
    Shorn355 likes this.
  7. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    Ahh- Then your carpet theory probably has merit- They would have had to mess with that to get to washer I believe- Did you contact dealer?
  8. rob lay
    Dec 1, 2000
    63,954
    Southlake, TX
    Rob Lay
    The pull cable on left was easy to find, first grabbed a connector, but second was the little T handle for the release. Came right open.
    Looking under bonnet nothing obviously interfering in the latch, I think it is more the fitting of the panel around the latch area. I push and tugged a little, but everything is firm. Something probably only a half inch off.
    Thanks!
