Front brake pad sensor question ('88 3.2) | FerrariChat
Discussion in 'Mondial' started by decampos, Dec 9, 2021.
  1. decampos
    decampos Formula Junior
    460
    Los Angeles
    Ben
    Hello all. The front inboard brake pads use a sensor that appears to be part of the pad and not transferable to the new pads I have (which don't have sensors). Am I right in thinking that I can just use the new pads and have nothing plugged in to the car's sensor wire sockets?
    FerrariJB likes this.
  2. moysiuan
    moysiuan F1 Rookie
    4,187
    Canada
    Odd, I have not heard of that before. Some sort of wear indicator, I wonder how that would work.
  3. decampos
    460
    Los Angeles
    Ben
    I've certainly encountered them but in my limited experience, the sensor is detachable and can be transferred to a new pad. I've attached pic of my Porsche 928 which has a detachable sensor.
    The OEM Ferrari pads have the sensors built in. I don't know when the Mondial began using this set up. I would guess most cars don't have them as they're really quite astonishingly expensive.
    My original question is me asking if I can have them 'deactivated' and their absence not create an electrical gremlin.
  4. afterburner
    afterburner F1 Rookie
    3,470
    Switzerland
    Urs STEMMLER
    When the pad wears the embedded wire will eventually contact the disc when the pad is almost worn down and with it ground the wire, which then in turn will light up the dash warning light.
  5. moysiuan
    moysiuan F1 Rookie
    4,187
    Canada
    Are the actual OEM pads available anywhere at this point?
  6. Rifledriver
    37,104
    Lots of aftermarket pads have sensors too. In many countries they cannot be left disconnected. Most name brand European pads are designed to have sensors. Some include new sensors and some sensors are an additional cost.
  7. moysiuan
    moysiuan F1 Rookie
    4,187
    Canada
    Can't seem to find any with my brief search. The main suppliers all say the part numbers are superceded to ones with no sensors, as far as I can tell.
    My search was not exhaustive, if anyone can link to front pads with the sensors that would be helpful to all. It is a good idea, and even though we all probably check brakes to make this redundant, I like to keep my car and all its features operating as new whenever possible.
  8. Rifledriver
    37,104
    #8 Rifledriver, Dec 10, 2021
    Who do you consider main suppliers? Have you tried G i r o d i s c? Have you tried T Rutlands, Have you tried AW Italian?
    Again who do you consider main suppliers?
  9. moysiuan
    moysiuan F1 Rookie
    4,187
    Canada
    Eurospares and Superformance are my go to sources, with good experiences with each over the years. Since I have a CH car they tend to have those specific parts available moreso than the US suppliers. Maranello Concessionaires too, they have gotten easier to order from over the years. I have also used Ricambi and AW Italian but ship charges from the UK to Canada often are less than from the US, go figure. Ferrparts and Rutlands I have used for ebay purchases, for stock I might need down the road.
    The local Ferrrari of Ontario is sometimes helpful too.
    Girodisc might be a good idea for the pads, but I have not dealt with them before.
  10. Rifledriver
    37,104
    I am not aware of a single professional who uses either of the 1st 2 you mention. . For good reason.
  11. moysiuan
    moysiuan F1 Rookie
    4,187
    Canada
    I am not a professional, just a determined enthusiast. The US suppliers are no doubt fine, but should try to make for better shipping arrangments for Canada, I can bring things from UK and Europe cheaper and faster. Try and get the special CH injectors for the KE3 on my Mondial, and see how many actually stock these. My dollar is also worth 70 cents to the USD, and I pay 15 percent sales tax and often customs or broker fees from US shippers. When I convert all the costs from various suppliers, delivery times, and also factor in actual parts availability, the UK suppliers seem to have an edge. I have had few problems over 15 years with any supplier, but I must say on one or two instances Eurospares has gone out of their way to be helpful.
    If there is a preferred supplier for good reason in the US, it is too bad these things are a secret. I guess us non-US enthusiasts are not a big enough market to fuss with.
  12. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    #12 Steve Magnusson, Dec 10, 2021
    Since the "normal" condition is "sensor wire not grounded/not connected to anything", using a pad without the wire (and just tying the sensor wire on the chassis out of the way) is fine (you will just never get the warning light coming "on" from a worn brake pad condition). In looking for new front brake pads for my TR, I've noted that some pads have the mounting provision for that Porsche-style wear sensor and some don't:
    ATE TR front brake pad without wear sensor mounting feature:
    TRW TR front brake pad with wear sensor mounting feature:
    Obviously, your front pads are a different overall shape, but I'd guess that they are not only Mondial-specific so may also be available in the two different flavors. If you want to keep that function working (and can find a pad with that wear sensor mounting feature), you might be able to get a removable sensor (like on your Porsche) and just connect it to your existing Mondial chassis-side wire -- just a thought that it might be worth the effort to look at some online pad pics (e.g., at Rockauto).
    decampos likes this.
  13. decampos
    460
    Los Angeles
    Ben
    Thanks Steve, that's very helpful.
