Front brake rotor ? | FerrariChat
Front brake rotor ?
Discussion in '456/550/575' started by ferraridriver, Oct 9, 2015.
  1. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Is there a good replacement rotor for stock brakes?
  2. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
  3. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
  4. 308 GTB
    308 GTB F1 World Champ
    11,721
    New Jersey
    Barry Wolinsky
    #4 308 GTB, Oct 9, 2015
    Dave,
    The GiroDisc 2 Piece floating rotors are direct replacements for the stock brakes: Rotors
    GiroDisc rotors are commonly found on F355 Challenge cars. The OEM cross-drilled rotors were prone to cracking.
    I have GiroDiscs on my car...
  5. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    I have the Brembo Brake option on my G35 Sedan driver and I'm able to buy the rotors individually from Brembo. And aren't 550 OEM brakes manufactured by Brembo without the logo?
  6. marce
    marce Formula Junior
    Jan 30, 2014
    454
    Australia
    Marcel
    My brakes are rotora, not sure if they will supply just the rotor, but i am very happy with them.
    Cheers
    M
  7. Bertt
    Bertt Formula Junior
    Nov 16, 2011
    277
    The Netherlands
    Bert
    I did some searching into that as well and believe you are right, the Brembo partnr. seems to be 09.6802.20
  8. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
  9. Bertt
    Nov 16, 2011
    277
    The Netherlands
    Bert
    I noticed there is a third bulk buy of complete sets of front & rear rotors coming up that also fit the 550. See the link (to see the pictures you have to register on the forum).
    Sports Maserati brake discs - third group buy
    Looks like it is better quality and a lot lower price than original. I have signed up for a set, perhaps there are more interested?
    Note that I am in no way affiliated to this bulk buy so don't see this as an advertisement, but merely as info that might interest others as well.
  10. BJJ
    BJJ Formula 3
    1,301
    Maybe a stupid question, but when I bought 4 new discs for the 550 a few years ago, I was surprised that the Ferrari-supplied discs were really not expensive, almost "normal" price level. Has that changed?
  11. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    Bernhard is right.
    The Brembo rotors for my 1994 Maserati Ghibli costs more than for the 550.
    If they raised the prices, i'm happy that i have bought rotors and pads for the front axle about 4 years ago, just to have them here in my stock.:)
    Daniel
  12. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    Saw that they raised the prices since i have bought mine.
    Daniel
  13. fatbillybob
    Aug 10, 2002
    29,004
    socal
    Dave,
    If you find some let me know or if you work a deal with girodisc let me know. I can always use a set. Maybe I'll check to see what stoptech can do. Sometimes they can make the hats for their rotors.
  14. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Finding replacement front rotors for the GT is not easy, as the rotors are smaller than the later cars.
    I have tried several suppliers and found none, although I did not try Giro Disc.
    I had even considered to buy new rotors of larger diameter and have them turned down to the correct diameter.
    Eventually my original rotors had enough material left to allow for resurfacing and further use.
    One other alternative would be to replace the entire unit rotors + calipers at the front.
  15. RDM
    RDM Karting
    Nov 22, 2010
    70
    Atlanta GA
    Doug Moffat
    Dave, I replaced my front rotors with cross drilled and slotted rotors from Frormula Dynamics out of Los Vegas....$295 each. I have had them for a couple of years and maybe 15K miles. I don't track, but the slots seam to improve heat disapation and reduce fade on mountain drives... Which was driving me crazy. With braided SS lines and Pagid pads, my braking is much improved for not much money. Doug
  16. Mike@Girodisc
    Mike@Girodisc Rookie
    33
    Belllingham
    Hello all Mike here from Girodisc, we offer our direct replacement two-piece full floating front rotors for the 550/456 that are 100% plug and play with the OEM calipers. Their two piece constriction saves about 4.5 lbs. per rotor and because they are proper directional vane rotors they run cooler than the OEM counterparts prolonging the life of both the rotors and pads. We actually have a 456 here as one of our shop cars which we've been running our front rotors and S/S pads all around on for the past couple years.
    Unfortunately we do not offer a rear solution for these cars, if we could we would. The issue lies in the parking brake diameter. In order for us to have room for the hardware that connects the hat to the rotor we would need to space the caliper out due to it's proximity to the parking brake drum. We run into the same issue with some of our Porsche kits however the calipers on those cars are radial mount so we can easily put some spacers under the calipers to get the clearance we need. On the 456/550 an axial mount caliper is utilized so we would have to manufacture a complete bracket to relocate the caliper and we just don't have a lot of real estate in there.
    If anyone is interested in the front rotors and/or pads please feel free to get in touch, we stock both for these cars!
  17. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
  18. tazandjan
    39,170
    Great rotors from Girodisc, now they just need some rear ones, too.
