Front Caliper question ?????? | FerrariChat
Discussion in '308/328' started by absostone, May 5, 2017.
  1. absostone
    absostone F1 World Champ
    10,064
    Are the 308 front calipers spacer 7 mm or 9mm?
  2. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,338
    Encino, Ca
    Carl T
    Well the diameter is closer to probably 15mm and the thickness is less than 1mm. So not sure what you are asking. Typically more than 1 spacer per caliper bolt is used to line up with the rotor.
  3. absostone
    10,064
    Center spacer for the caliper halves
  4. absostone
    10,064
    I'm pretty sure the center spacer should be 9 mm. My front calipers are at pmb for restoration and they said my spacers are 7mm.bon my 75 308 gt4 Does 2mm make any difference with all the piston travel?
  5. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Front caliper spacer on Ferrari are 9mm the Porsche is 7&11. Just went through this with PMB
  6. absostone
    10,064
    Yes thx. What I thought. The gt4 is a early car maybe 7mm spacer? With the 9mm the piston would get m extra travel? Just got off the phone with them and was told they are early calipers and original early seals. Ferraris wth
  7. absostone
    10,064
    Btw should I put them back to 9s??? What I'm thinking
  8. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,338
    Encino, Ca
    Carl T
    When it comes to ATE calipers, your in goods hands with Eric.
  9. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    The concern i would have is caliper / disk interference.
  10. absostone
    10,064
    Yes good guys I had the rears done last year
  11. absostone
    10,064
    They have been on the car for 16+ yrs of ownership. It's only two mil ya know? I'm gonna have them change it to 9s I guess
  12. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Unfortunately Eric does not do all of the work himself. I just sent my front calipers out and when they came back I had flow problems with brake fluid through some of the holes. I blew them out with brake cleaner and grease came out of them. Good thing I check them before I put them on the car. Just saying.
  13. absostone
    10,064
    well things happen. I'm on three broken windshields in the past 2 mos
  14. absostone
    10,064
    Thank u all for the replies. Pmb mismeasured. They are 9mm. Case closed
