Front challenge grill 360 | FerrariChat
Discussion in '360/430' started by cre_man, May 13, 2018.
  1. cre_man
    cre_man Karting
    Aug 8, 2017
    97
    The Netherlands
    Hi Guys,
    Couldnt find it in my searches. Well not a definitieve awnser.
    When you have a Modena coupe And you want to upgrade the OEM front slicer grills to the CS style challenge grills. Do you just Need the grills. Or do you Need brackets And grills?
    Please give me the info so I can start searching or Maybe somebody has something laying around.
    Thnx René
  2. Skidkid
    Skidkid F1 Veteran
    8,756
    Campbell, CA
    John Zornes
    If you want it to look right, you need the bezel and the grill.
    cre_man likes this.
  3. timwu12
    timwu12 Formula Junior
    919
    TX
    cre_man and gt1995 like this.
  4. cre_man
    cre_man Karting
    Aug 8, 2017
    97
    The Netherlands
    Great! Now let’s see id this is a DIY job or a dealer upgrade.
    And the towhook? Is the screwhole still useable?
  5. becausephilchow
    becausephilchow Formula Junior
    Aug 26, 2016
    543
    Hong Kong
    I picked mine up from ProSport Ferrari in the UK. Fit quite well. Can be done DIY if you are able to remove the bumper. Nothing difficult, just a bit time consuming.
  6. timwu12
    919
    TX
    cre_man likes this.
  7. cre_man
    cre_man Karting
    Aug 8, 2017
    97
    The Netherlands
    Great. Thnx for your help
  8. rizzo308
    rizzo308 F1 Rookie
    2,693
    Perth, Australia
    riggio
    You don't need to buy the CS plastic bezel For $200 + each ur havin a laugh.:D
    Your standard bumper grills are the duks nuts they'll work fine. Simply cut the slats out of the standard slicer grills flush with the outer frame (red arrows) as close as u can I used a hacksaw blade on it's own wrapped a bit of tape around one end to make a handle protect wee fingers. Cut out all 8 fins once cut out sand down any high spots say 120 or 80 grit paper then scotch pad the hole thing plastic primer it (I have p primer in rattle can) then it to ur local body shop get them to spray some primer putty on it sand it nice and smooth paint it black. Huchi mamma. If u need a repo CS tow hook to go with them CS grills PM me. Gud Luk
    cre_man likes this.
  9. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    cre_man likes this.
