Front challenge grille (360)
Discussion in '360/430' started by exiges, Mar 8, 2004.
  1. exiges
    exiges Karting
    Feb 26, 2004
    199
    Midlands
    David Brown
    I know what the rear challenge grille looks like.. not hard to spot !
    But I see references to front challenge grilles and I can't say I'd know one if I saw one.. Can anyone posts pictures of two cars, one with, one without them so I can see what they are ?
  3. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    #2 tonyh, Mar 8, 2004
  4. phil30
    phil30 Formula Junior
    Nov 13, 2003
    785
    Somewhere I belong
    Phil Tan
    The stradale's front grills looks like it is made of thinner wire mesh compared to the standard ones, is my understanding correct?
  5. ddemet
    ddemet Karting
    Dec 11, 2003
    126
    Switzerland (VD)
    The 'challenge' front grille is made of the same mesh as the side air intakes, diagonal and smaller than the 'normal' grille.
  6. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Here's a shot of my car with the factory Challenge grills. One caution is that the tow eye hole on the driver's side does not line up with the hole in the Challenge grill. If you car ever need to be towed, minor surgery will need to be performed. RM Racing makes a set but not sure they have a problem with alignment.
  8. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Here's an old picture of my car with the original grills.
  9. SefacHotRodder
    SefacHotRodder F1 World Champ
    Dec 20, 2003
    10,921
    NJ
    Chris
    lovely car willis
  10. zjpj
    zjpj F1 Veteran
    Nov 4, 2003
    5,938
    1. what's the price of the option?
    2. I think it looks great, but what does it do for the car? Obviously rear challenge grille helps to cool the engine. What does this do?
  11. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,376
    Himalayas
    1. not sure
    2. helps prevent larger debris (like leaves) from entering via the grille.
  13. jeff
    jeff Formula 3
    Feb 19, 2001
    1,924
    North America
    I have a 2002 and the tow eye hole DOES line up with the hole in the Challenge grill. Ferrari probably fixed this starting with MY 2002?
  14. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Thank you.
  15. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Over $600 for the pair from the dealer.
    I found that it does a good job keeping debris ( mostly leaves and larger pebbles) from entering the openings. The original grills basically let everything inside.
  16. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Interesting, Jeff. Perhaps it's fixed. The front grills were not offered as an option when I ordered my Modena back in 2000.
  17. JSinNOLA
    JSinNOLA F1 World Champ
    Sponsor Lifetime Rossa
    Mar 18, 2002
    16,456
    Denver, CO
    $600??????
    LOL, what a gip! Can't imagine why these are not standard equipment.
  18. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Hey, you should have seen my reaction at the parts counter when I picked them up! :)
    Yes, they should have been standard. IMHO.
  19. JSinNOLA
    Mar 18, 2002
    16,456
    Denver, CO
    I am sure the parts counter was quite used to customers giving the same type of reaction you gave! I still am smiling to myself about the $600 fee.
    Must be because of all the tough engineering and windtunnel work that went into that mesh wire:)
    Regardless, it looks better now and I am sure that you are happy you did it. I have always liked the look of your 360. Whether or not other people notice that you have the grills is meaningless. Sometimes small things like that give you peace of mind.
    In the end I guess I would rather pay the ridiculous $600 than have a bird or squirrel sneak in there at speed!
  20. zjpj
    zjpj F1 Veteran
    Nov 4, 2003
    5,938
    haha, that happened to me once. (not in a Ferrari of course...) I didn't notice until the next day when I came into the garage and noticed a peculiar smell. Then I saw the feathers sticking out behind the liscence plate... :)
  21. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,490
    The challenge grill for the front of the 360 is composed of a wire mesh on frame and composite trim ring that backs up the grills. It takes about $300 for each grill and about $165 for each trim ring. You will need to remove the bumper to install them. About a 3 hour job at the dealer. So about a $1k to get them installed including the parts.
    I did not care for the quality of the OEM piece so I made my own set out of stainless. I also have made some grills for the other 7 intake ports on the car. The upper and lower intake, the rear pipes and center tunnel. If interested send me an email and I can price out a set for you. Either in stainless silver finish or black. Also other mesh types available.
