Front engine LMP | Page 3 | FerrariChat
Front engine LMP
Discussion in 'Other Racing' started by ND Flack, Jan 27, 2015.
  1. BartonWorkman
    BartonWorkman F1 Veteran
    Nov 3, 2003
    6,184
    En El 305
    Barton Workman
  2. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    The Porsche guy is right, seems foolish to not use the maximum amount of tire allowed in the rules. I can't think of any reason they would do this other than that they can't the right balance otherwise with this car configuration. I don't think this concept will work, but hope I'm wrong. On paper the GT-R is too big and heavy to perform but look at what it does.
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    That's kinda what I figured, but I'm still wondering why they aren't covered. I can understand louvers being over the holes to vent the air, but nothing on them at all? It just looks odd. Not that the car is all that attractive anyway. But it's purpose is to win races, not look good. So long as it gets the job done I guess.
  4. tervuren
    tervuren Formula 3
    Apr 30, 2006
    2,469
    The change was made for two reasons.
    Rubber and debris can clog vents.
    Vents can be exploited to not function properly at certain speeds.
  5. tervuren
    tervuren Formula 3
    Apr 30, 2006
    2,469
    Less weight over the rear, the rear is doing less heat. You pick tire width based on heat dissipation and heat build up. Narrower tire = less dissipation and more build up for a given amount of work. Less work, maybe they can get away with it.
    In a RWD car, the rear tires are working down the entire straight away building heat, being used for braking building heat, and being used in cornering building heat. In this Nissan, as down force builds, the front tires end up doing most of the work, allowing the rear tires to cool.
    The difference in tire width aerodynamically may pay off against the heat management.
    This will be an exciting race car to see perform. It harkins of the GB R1 & R2 in its tear drop design when veined from above.
    Reliability, not lapspeed, will be the Nissan's downfall.
  6. BartonWorkman
    Nov 3, 2003
    6,184
    En El 305
    Barton Workman
    Recalling the days that the wheel wells were ventilated with louvers and a lot of the time,
    the rubber that the tires threw up was going right through them. Usually by the end
    of races, there wasn't much left of the louvers.
    Having seen pieces of rubber the size of footballs flying off P-1 cars, it damages the louvers,
    which can go flying off and then cut the tires of other cars.
    So, there is the safety issue as well.
    At the Sebring SVRA/TransAm race this past weekend, teams were scrambling to get the
    sealer that the track has put down in the cracks out of their cars. After their first 20 minute
    session, all of the TransAm cars looked as though they were on the track for three hours
    or more such as the accumulation of sealer in and on the cars.
    BHW
  7. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,757
    Boston, MA
    John E. Kenney
    And the Toyota flip a few years later at Le Mans. The front engine car is blowing exhaust over the body inside of the wheel arches. But you don't want lift there do you? Strange. I guess it's a response to the Delta Wing fizzle. Any news on that?
  8. BartonWorkman
    Nov 3, 2003
    6,184
    En El 305
    Barton Workman
    Just read that the Nissan has been scratched from testing for the rest of the week
    with a "carbon issue".
    Not quite sure what that means but likely a chassis problem that can't be fixed
    at the track.
    BHW
  9. CornersWell
    CornersWell F1 Rookie
    Nov 24, 2004
    4,906
    While it's completely hideous, IMO, I certainly give NISMO credit for bringing a clean-sheet design to the track. I have some idea of the amount of investment it takes to bring something like this from drafting board to reality, and it's not a small sum. In addition to the design and manufacturing, of course, NISMO has to pay for the racing operations (probably contracted out, but maybe internal) and that's not nothing, either. It will take some time to sort the issues, too, and that will be an expensive (and humbling) process.
    Good luck to them, but I don't see this as being a class-winner.
    CW
  10. BartonWorkman
    Nov 3, 2003
    6,184
    En El 305
    Barton Workman
    Now on Jalopnik.
    Rather surprising how open Nissan were allowing photographers to crawl all over
    the car in the Sebring paddock this week especially given that it's a brand new car
    and barely broken cover.
    Audi on the other hand were bivouacked on the far side of the circuit with their compound
    set up on the test track pit lane with an HVACed marquis tent serving as their garage, it may
    be assured no cameras were allowed.
    In any case, the Nissan rear suspension is an interesting case study. They're making as
    much room as they can for this flow-through tunnel.
    A Closer Look At The Nissan LMP1's Incomprehensible Rear Suspension
    BHW
  11. BartonWorkman
    Nov 3, 2003
    6,184
    En El 305
    Barton Workman
