Guys, I need to adjust the front fog lights on my Mondial 3200 One is aiming for the tree tops, the other is way too low Do I need to take off the bumper to get to the adjustment screws??
If it is like in my 328, you need to remove the signal lens and adjust the screw inside. I can't remember if the adjusting screw is on the left or right side .... Maybe I can find a picture of it
Rui, I saw 3 screws when I removed the plastic lens on top of the fog lens Think there were 2 together towards the car centre One of those should be the one, the other 2 are for holding the unit I will give it a try tonight, will take a picture Unfortunately there is also a bad contact in the signal wiring The lamp itself is OK but does not glow, the side indicator and the rear one are working The parking lights are working as well So maybe I will have to remove the whole unit to access the connections Looks like new on the inside though Obrigado, Frank
Here's the picture showing the only 2 screws you have to undo to pull the assembly out. The other (bigger) screw is the adjustment. Image Unavailable, Please Login
OK I thought there was a 3rd screw but it was a pin that you can just pull out of its hole I found the indicator problem was the male pin in the connector not being held in So when you connect the plug (4-way) the pin was pushed out The heigth adjustment worked just fine Just need to have a small crack repaired in the windscreen and I am ready for Francorchamps on the 14th Rui thanks again
