430 - Front Glove box button | FerrariChat
430 Front Glove box button
Discussion in '360/430' started by Mjzinno, Mar 8, 2022.
  1. Mjzinno
    Mjzinno Karting
    Jul 12, 2021
    56
    M Zinno
  2. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    834
    Michigan
    Tony
    You need to remove the faceplate that contains the center three vents in order to get to the back side of the button. The workshop manual will tell you that you simply insert a flat blade between the front of the switch and opening to compress the spring. Trust me, it does not work. Much easier to take the time and remove the face plate (and stereo plate as well if I remember correctly). You can then access the button from the rear and depress the springs holding it in place. I found it was easier to do it this way then removing the glove compartment. Been there, done that.
    Qavion likes this.
  3. Mjzinno
    Mjzinno Karting
    Jul 12, 2021
    56
    M Zinno
    Thx! That is very helpful. Sounds like a lot for such a small button!
  4. 66ss427
    66ss427 Formula Junior
    439
    N. Myrtle Beach, SC
    Dominic
    338Lapua likes this.
  5. 338Lapua
    Sep 5, 2015
    834
    Michigan
    Tony
    Like Dominic is showing in the pics, it's the two flat springs you need to compress. Accessing these springs from the back will ensure you don't mess up the leather on the dash.
  6. Mjzinno
    Mjzinno Karting
    Jul 12, 2021
    56
    M Zinno
    Thx guys!!
    66ss427 likes this.
  7. 66ss427
    439
    N. Myrtle Beach, SC
    Dominic
    Hope you give it a go !!!
    I did it twice when I was sending my original to be redone at StickyRX. I put in a spare, so I wasn’t in a rush to get it back.
    Just remember, nothing sharp and you will be fine !!!
    Good Luck,
    Dominic
