Front Grill replacement F40...pics | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by RufMD, Feb 11, 2008.
  1. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    #1 RufMD, Feb 11, 2008
    Had some spare time this weekend :)...decided to replace the front lower grill on the F40. Its easily damaged by rocks etc...OCD types like a nice straight grill :)
    US F40's have the lower grill held in place by 6 rivets...black rivets to be exact (they are on their way from Ferrari). I drilled out the old rivets, disconnected the horns from each side, and removed the right side air deflector (by drilling a rivet out)...the grill then has enough clearance to come out. I'm also replacing the radiator foam...its just lying on the radiator and is going to be positioned.
    Here are some pics I took...I will post the final update when the new grill is placed.
  2. StoryBook
    StoryBook F1 Rookie
    Mar 1, 2003
    4,304
    PNW
    MPL
    I am assuming that the "old" rivets cannot be re-used?
    Interesting that the designers didn't just use re-usable bolts to bolt that grill in. Oh well.
  3. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    I love your garage!
  4. [355]
    [355] F1 Veteran
    Apr 10, 2006
    8,482
    Spacious tent
    Harold Faltermeyer
    the old ones are 'drilled out' -ie drilled out to the diamater of the hole in the bodywork so they just crumble out
  5. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Funny thing is, when you look at the parts manual for the grill, it shows that the euro versions are screwed in ! For some reason US cars are riveted. Maybe some of the euro car owners could confirm if indeed the grill is screwed in place.
  6. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Thanks Ryan, my wife calls it the "cave"...:)
  7. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    correcto !
  8. Jati
    Jati Formula Junior
    Dec 3, 2004
    299
    Florida & NC
    Joe G.
    Jas,
    I am in the process of changing my grills out now......Did you locate factory rivets, or go with the black-faced automtive rivets?
    Would love to know the correct size before I drill mine. Also, where did get the replacement radiator seal? Ricambi told me they were no longer available from Ferrari. I use adhesive backed PVC foam...but had to use two rows since I could not find anything wider than 1.5".
    I posted about it last week..But it was overshadowed by pictures and the odd bantor from our pal in Queenland. ;P
    Joe
  9. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Joe,
    Speak to David at Ricambi, extension 105, he is getting me the rivets. Also, I got a NOS foam radiator seal...but it had deteriorated over time sitting on a shelf...again, I got a replacement one from Rutlands and it was fine. I used a 5/32 drill bit on the rivets, this pops off the head, and then you can rotate the drill slightly in the rivet hole to clean it out without enlarging it too much. You may want to pop one of the rivets on the right air deflector to rotate it out of the way....this allows the old grill to clear without any bending/stresses. I would recommend masking of the paint area in the front scoop so that the new grill insertion doesn't slip and scratch.
    Thats about it !
  10. Rev.ATARI
    Rev.ATARI Formula Junior
    Sep 20, 2004
    683
    Guam USA
    Leland Jones
    Can I come over sometime?
  11. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Its a bit of a drive for you...but sure ! anytime !
  12. amenasce
    34,463
    Joe Mansion
    Sorry Jas but i cant read if you post pics of your garage..too hard to stop looking at the cars.
  13. Wolfgang5150
    Wolfgang5150 F1 Rookie
    Oct 31, 2003
    4,706
    RufMD - I take it that your floor is painted industrial epoxy? If so - how has it worn over time? It looks great (From the limited view in these photos).
    Thanks.
    Kevin
  14. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Kevin, I have chosen a different surface for the next garage being planned. The epoxy has lifted in a few areas that are under contact with warm tires. The floor was acid prepped/washed and double coated with epoxy, but still lifted in some spots. Also, when wet, this surface is treacherous to walk on. With a little one, and another on the way, it becomes a safety issue....a little bit of snow on the shoes and its skating time !
  15. 1ual777
    1ual777 F1 Rookie
    Mar 21, 2006
    2,948
    Orange County, CA
    Is that one of the reason's she is now an 'ex?'
  16. 1ual777
    1ual777 F1 Rookie
    Mar 21, 2006
    2,948
    Orange County, CA
    Did you check out his 'daily ride' in the lower left hand corner? All he needs is a 110v spot each way on the commute.
  17. Wolfgang5150
    Oct 31, 2003
    4,706
    Thanks - I was wondering about that. What will your next garage floor surface be?
    Thanks.
    Kevin S.
    Orchard Park, NY
  18. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    happily married and never divorced my friend....
  19. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Kevin, the next surface is going to be slate/stone, that has been sealed. There is an outside chance that I may do polished concrete with some colouration added, but as of now it looks like grey slate.
  20. Rev.ATARI
    Sep 20, 2004
    683
    Guam USA
    Leland Jones
    I will be back in Dallas around May, maybe I should visit Kentucky as well :)
  21. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Sure ! Catch the Derby, and experience some other "horses" at the same time !
  22. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    :) I KNOW you have a lot of personal experience looking at a garage full of sweet cars...post some of your shots my friend !
  23. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    Great thread. My grill is in rather good shape but I shall remember these details
  24. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    My grill is also perfect in spite of all that "spirited" driving...
    Joe
    www.joesackey.com
  25. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #25 Napolis, Feb 12, 2008
