Front header's cracked . . . engine's coming out? | FerrariChat
Discussion in '308/328' started by luckydynes, Jun 5, 2007.
  1. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Hey all,
    Just did a search . . . looks like I'm pulling my motor to fix a crack in the front header. Funs over (or just beginning?) for a few days.
    I've got a light weight flywheel that takes the twin disc clutch . . .. might put that in while I got her out.
    Sean
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,888
    Atlanta
    John!
    How on earth did that header get a crack in it? Was there a misfire on that bank and the manifold just got too hot?
  3. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,325
    E ' ' '/ F
    Splenda Daddy
    Any other way to get to that header?
    Mine just developed a crack at the exhaust test tube :(
  4. BigTex
    79,399
    Houston, Texas
    Bubba
    Hold on! Unless you just WANT to yank it out....:rolleyes:
    You can get it out thru the RH wheel well if you drain and remove the gas tank on that side....
    Been there, done that...
    Your call........
  5. dstacy
    dstacy F1 World Champ
    Jan 23, 2006
    11,999
    GMT -5 & GMT +1
    Dave
    I don't know....there has to be a way doesn't there?
    I wonder if you called one of the experts like Stanford or Pollard, etc. if they'd know a trick.
  6. BigTex
    79,399
    Houston, Texas
    Bubba
    I just gave it to him.......
    Pull the motor mount bolts and jacking the engine slightly can help also......get after it!
  7. BigTex
    79,399
    Houston, Texas
    Bubba
    Mine fell out in two big pieces...and there some fragments apparently left in the road as well.....LOL!
  8. dstacy
    Jan 23, 2006
    11,999
    GMT -5 & GMT +1
    Dave
    I swear Tex....is there anything you haven't done on a 308? You know every trick in the book.
  9. BigTex
    79,399
    Houston, Texas
    Bubba
    Yea, actually TUNE the gosh darned thing............LOL!
    It just happens that the header failure was the FIRST thing to go wrong with #22127, before I met JRV........it was that failure that led me to his door.
    He looked at the pieces in the bed of my truck and said:
    "Those should last a lifetime, you have something else wrong with the engine"...and as usual, he was correct, we had to totally go thru the ignition and carburation once we had it back together.
    All the rest of my headers lasted thru HIS lifetime, anyway.....:rolleyes:
  10. BigTex
    79,399
    Houston, Texas
    Bubba
    The rear one blew apart a few months later, but by then I was used to the car bursting into flames.........got my daughter and her gf out of the car and put it out........
  11. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    It's nice to know it can be done without pulling the engine.
    I'm going to send a pic of the crack/break . . . it's all the way around one of the pipes about 1" before it goes into the first collector section . . . might have to completely cut the header up to fix it. Did that already with the rear header.
    I thought I replaced the motor mounts but the motor still seems to move quite a bit by hand . . . grab the top of the plenum and can rock it around about 1/2" . . . normal? If the movement isn't normal it might have caused the crack.
    BTW I have my car up on a rack . . . makes jacking up the engine more tricky. . . hopefully won't have to do that.
    Thanks,
    Sean
  12. BigTex
    79,399
    Houston, Texas
    Bubba
    IMO it's just thermal cycling generating the fatigue, spotty construction quality to start with.....
    Ignition malfunctions do not help....used units are hard to find, that tells you something!
    Later versions used spring loaded bolts at the tri-flange, from the 328 and F40 parts book.......
    Qucksilver and Tubi are making replacement units now, IIRC......no experience with either vendor but it's only a matter of time...
  13. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #13 luckydynes, Jun 5, 2007
  14. BigTex
    79,399
    Houston, Texas
    Bubba
    Your rear engine brace at the top is still in place?
    That sounds like too much movement, to me.......
  15. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,651
    Toronto / SoCal
    Rob C.
    If your car is a North American spec with the shielding over the header, it is easier to remove the engine than pull the header out. I did this job a couple of years back and removing the header is THE most tedious mechanical job I have ever done. It does come out with the engine in however it is not at all worth the effort. It is much less time to pull the engine and a ton less grief. Once I was done I felt like a fool for not pulling the engine. Not only that, with the engine out you can tackle a bunch of other small projects that are a pain with the engine in but take minutes with it out. Lastly with the engine out you can detail everything and powerwash the engine bay with almost no problem at all.
    If you have European headers or all the shielding has been stripped off of your header then removing it is pretty easy and should not take more than 2-3 hours.
    In summary:
    Can you get it out without pulling the engine: YES
    Is it worth the extra effort: NO WAY
  16. BigTex
    79,399
    Houston, Texas
    Bubba
    "Mr. Blobby was a Ferrari factory welder...."
    I think I read that in a Doug Nye book once.......
  17. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Looks like there could've been some previous repair on it, or is that just some Italian workmanship?
    Lot's of hard driving last weekend and it was hot.
    Sean
  18. BigTex
    79,399
    Houston, Texas
    Bubba
    That looks original to me........can you get all the way around it with good penetration?
  19. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    The heat shield is already gone off the front header . . . wrestle it out or not?
  20. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    It'd be a pain on the side where the other tube is. My rear header cracked I had to cut it all apart to get to it . . . I'll see once I get it out.
  21. BigTex
    79,399
    Houston, Texas
    Bubba
    There's the rub, and the fact the metal's so old it'll crystallize and crack at the edge of the new bead.......your call!
    There's a thread on 'ultimate 308 exhaust system' that discusses new headers......
  22. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Well I'm draining the gas tank. There's no other reason right now to pull my motor and hopefully with the heat shield gone it won't be a total nightmare.
  23. BigTex
    79,399
    Houston, Texas
    Bubba
    Yea, I know it sounds easy to yank it, but shifting linkage, other attachments, breaking the rear window.....all are factors for other methods.....
    We'll drop a valve soon enough......;)
    THEN we'll yank it out of there.........
  24. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Well, I pulled mine out through the bottom. I figured I needed to pull the console out anyway, so how hard would it be to pull the shift rod out? That was actually pretty easy. Oh, the alternator and starter held it up too, so off they came. I could almost get it out, but the motor just wouldnt let it pass. So I removed the muffler, disconnected the coolant lines, pulled the motor mounts, disconnected the clutch and jacked up the engine. Nope. unbolted the oil cooler and hooked up the cherry picker and really lifted up the motor. Nope, &$@(*$#@ it. I might as just as well have pulled the motor out, as I already had everything unhooked except the drive axles. By lifting it WAY UP and back, I finally was able to fish it out, but DO NOT DO IT THAT WAY.
    I know as they went up in years they get harder to work on, more stuff in the way, fatter parts etc., but really, if that gas tank had been out of the way it would have come right out of there. Just pull the tank. Those welds look like crap and are full of slag holes, looks like an old repair. If it was possible to have the headers heated up in a high temp oven after you repair them, cherry red for about an hour, it would anneal them and prevent further breaks for a while. Thats probably the one really good thing about having them ceramic coated, they get annealed real good.
  25. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #25 luckydynes, Jun 5, 2007
    Well that was easier than pulling the motor.
    My car already has a bunch of stuff removed plus the fact it came off in two pieces made things a little easier.
    Fixing it'll be fun.
    I remember Superformance being pretty reasonable for a replacement when my rear header broke but it only ended up taking a couple hours to fix once I figured out how to go about doing it . . . not sure this'll be as easy.
    Sean
