348 - Front hood stuck closed on one side | FerrariChat
348 Front hood stuck closed on one side
Discussion in '348/355' started by Cowboy-14, Oct 7, 2019.
  1. Cowboy-14
    Cowboy-14 Rookie
    Nov 27, 2016
    2
    Central NJ
    Ben
    Hello All,
    I have been helping my brother work on his 348 lately. After doing the cam belt service ourselves, we are starting to feel pretty good about ourselves :)
    Here is our latest issue. The front hood is stuck closed on passenger side. Driver side latch opens. Pass. side will not budge! The release handle is very tight( he says it was always that way). We know there is an emergency release on Pass side dash, but it will not move at all. The cables seemed a little tight to him, so he wanted to lube them. He must have done something wrong without realizing, so now we have this issue.
    Does anybody know of a way to get this thing open? The "emergency" release I think will be a dead end. Can we get in there and pop the latch loose somehow?
    Any thoughts will be greatly appreciated. Thank you.
    Ben
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,284
    Serbia - Niš
    Miroljub Stojanovic
    If the pin on the pass side is somewhat misaligned with the socket, it may be catching even though it is unlatched by the cable. Try first, with the opening cable held in pulled position, to press/release repeatedly and also wiggle in all directions the corner of the bonnet. It may pop out.
  3. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
  4. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Have you tried to release the pass side first? Also, try lifting the edge up as you activate the pass side 2ndary release. You might be able to goad it up.
  5. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    Try pushing down slightly on the hood when pulling on that emergency release worth a shot.
  6. Cowboy-14
    Cowboy-14 Rookie
    Nov 27, 2016
    2
    Central NJ
    Ben
    Hello All,
    We have tried pushing and pulling on the hood, but didn't want to do it too hard. Have not had much luck that way. We try some more though.
    You have given me a few more ideas we will try. Will mess with it tomorrow, keep you posted. Thank you.
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    This is what I'd do ^
    But have a person pressing down and holding at each corner, just above where the latches are (but not at the corners, don't want to bend anything). Then have the third person pull (progressively) the release handle.
