front indicator buld holders | FerrariChat
Discussion in '206/246' started by snowsports1, May 28, 2014.
  1. snowsports1
    snowsports1 Formula Junior
    Jan 31, 2013
    918
    Brian
    #1 snowsports1, May 28, 2014
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    You want 1157 bulb holders
  3. snowsports1
    Jan 31, 2013
    918
    Brian
    Hi yes, do you know who sells them with the 3 tabs so they fit?
  4. racerboy9
    racerboy9 F1 Rookie
    2,651
    I bought some from a vendor at Padova. I might have his info. Will have a look tonight.
  5. racerboy9
    racerboy9 F1 Rookie
    2,651
    #5 racerboy9, May 29, 2014
    Here are the pieces I bought at Padova. The vendor said he had the whole assemblies but not with him at the time so I grabbed what he had.
  6. snowsports1
    Jan 31, 2013
    918
    Brian
    great that's what I need, are these spares? can I buy them or can you tell me where you bought them please.
  7. racerboy9
    racerboy9 F1 Rookie
    2,651
    Is this all you need? There is also the spring and the part with the contact for the bulb. That is what the vendor had but not with him at Padova.
  8. snowsports1
    Jan 31, 2013
    918
    Brian
    I have various bulb holders I have bought to use for this, none have worked, but I can use the bits from them to complete the job if I have two of the items you have pictured.
  9. racerboy9
    racerboy9 F1 Rookie
    2,651
    These are for a single contact bulb with the locking pin at the same height on the bulb base. The two contact socket has one high and one low slot for the bulb which has a high and low locking pin. I'll try to find the name of the vendor as he has all this stuff.
  10. snowsports1
    Jan 31, 2013
    918
    Brian
    Uk indicators use a single contact bulb so this is correct
  11. racerboy9
    racerboy9 F1 Rookie
    2,651
    Send me your address and they are yours-no charge.
  12. snowsports1
    Jan 31, 2013
    918
    Brian
    What a gent, thanks racerboy9, I owe you one.
