Front leaks | FerrariChat
Front leaks
Discussion in '360/430' started by spikes360, Oct 17, 2014.
  1. spikes360
    spikes360 Formula Junior
    Apr 1, 2013
    420
    Niles, IL
    When I pulled out of the garage this morning I noticed a few leaks directly under the center/middle of the hood (front). Looks like some of it is a little trail that dried up and then there's a dime size drop of bloody red fluid. Would you think that this is a leak from the radiator and brakes?
  2. Skidkid
    Skidkid F1 Veteran
    9,523
    Campbell, CA
    John Zornes
    Power steering
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The red is possibly from power steering. If the other is dried-up it is likely condensation from A/C or maybe windshield washer solution. Coolant and brake fluid do not evaporate quickly.
  4. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    Yep, just went through this. Check your power steering reservoir level. Mine was simply a loose connection on the pump but it required the engine panel to come off to fix it.
