front license plate | FerrariChat
front license plate
Discussion in 'Ferrari Discussion (not model specific)' started by aatiya, Jul 30, 2007.
  1. aatiya
    aatiya Rookie
    Sep 17, 2006
    1
    Recently stopped by CHP for speeding. He was nice enough to offer me a fix it ticket or speeding. Of course I chose the fix it ticket. Now the dilemma: He gave me a fix it ticket for no front license plate. Any solutions for mounting a front license without drilling holes in the bumper of a 430. Maybe I should of chose the speeding ticket??
  2. VisualHomage
    VisualHomage F1 Veteran
    Aug 30, 2006
    5,611
    San Antonio
    run the plate on your dash board and the cops nor parking ticket officers ever cite for those as far as i know. and with dash board placement, you can take it out easily and stow it if you need to go vanity style. and you don't molest your car.
  3. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Have seen California plates via digital photo laminated on the front bumper. ;)
  4. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    ^^^that's a good idea. never thought of that.
  5. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    Doesn't work in CA.
  6. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    it has worked for me. the parking posse' comes around my street every day and they don't touch my car if my front plate is displayed on the dash. they day i have it out of the window ---> ticket.
  7. Bullfighter
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    A plate sitting on your dash isn't in compliance - check the DMV site/motor vehicle code.
    If you're stopped by a real CHP/LAPD officer, you will get a ticket.
    To the OP: Maybe post in the 360/F430 section - I'm sure others have had this issue.
  8. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    the codes you cite notwithstanding, if you run a plate on the dash you will more than likely not get cited. take it away and the story changes. i've done this on my street. the day i took it out i got a ticket for no front plate displayed. put it back in, nobody ever touches me.
    but do as you wish.
  9. DGS
    DGS Seven Time F1 World Champ
    72,523
    MidTN
    DGS
    I finally gave in and had a front plate bracket for the 328 fabricated and installed by the local dealer.
    The important point is that the attachment to the car should be stronger than the plate.
    That way, the plate makes a handy curb feeler on parking garage ramps; only the plate gets deformed -- before anything pretty gets dinged. ;)
    (Okay, technically, I suppose it's mounted lower than code would like, but it's mostly out of the radiator airflow, and this way I get *some* use out of the thing.)
  10. PhilNotHill
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Laminate before it's too late.
    A bracket is a racket. :D
  11. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I have mine held on with a couple of tie wraps- easy to remove for shows etc. Police leave you alone.
  12. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    It's still illegal. Just zip tie it up there, take a picture, bring the picture into the circuit court. Then it's dropped. Or pay the $77 and get on with life. I've had over 10 of those tickets, 8 have been dropped. Plus if you ever rear end some one with it in your dash...it will fly up and decapitate you!!
  13. wetpet
    wetpet F1 World Champ
    10,210
    put it on the passenger side so it gets the wife.
  14. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    A small amount of silicone. Use some double stick mirror tape to hold it in place while the silicone drys. Or... why not drill a couple of small holes? The license plate has to be mounted and if you sell the car the next owner will also likely have to mount plates. Hole spacing is standardized so I don't see it as a big issue. Measure twice, drill once.
    Quite frankly I've never understood why some states do not require front plates. Plates are on the car for the purpose of identification. Is it only important to identify a vehicle from one end or when it's travelling only in one direction?? Makes no sense.
  15. Modenafan
    Modenafan F1 World Champ
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    Not sure where you're located, but Dave at Premier says he has something to adhere the plate to the bumper for inspection and then he can remove it afterwards without leaving a mark. You might want to call him. Good Luck.
  16. Bullfighter
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    And please post whatever you learn - I'm sure I'll have this issue on the 328 at some point.
  17. Bullfighter
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    So wait, you're saying having a sharp piece of sheet metal on the dash is a bad idea... :rolleyes:
  18. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Euro Plates are different sizes than US license plates - a Euro plate could easily be mounted, with no overhang, across my 308 front bumper. A US-spec plate would block my radiator, causing the car to overheat. The REAL reason US states mandate a front plate isn't for ID purposes, its to give the cops' Radar/Laser speed guns a flat reflective surface to aim for and obtain decent speed readings to prosecute/cite you with.....
  19. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    I'm dealing with a front-plate ticket right now in Texas. I really don't want to block the radiator on my 308, so I've thought about a slim-line Euro plate mounted on my lower Euro valance lip. Some have told me this is not legal, but I'm willing to give it a try.
    Question is, where can I order a Euro-style plate with my Texas letter/digits on it?
    Thanks,
    Greg
  20. SrfCity
    SrfCity F1 World Champ
    Just use some double sided 3M tape and attach it. It won't budge to the touch. Then to remove use a hair dryer. Heat the plate first and it'll come off then just heat and peel the rest. Cheapest and easiest solution ;)
  21. Badman
    Badman Formula 3
    Mar 4, 2007
    1,116
    Gotham City
    Bruce Wayne
  22. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,819
    Cerritos, CA.
    Just make sure you don't rivet it to the bumper:D
  23. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
  24. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    This has to be the ULTIMATE license plate system !
    (Scroll to the red car in the middle of the screen and watch the front plate.)
    http://tinyurl.com/2kmpr6 (I'm not affiliated with this company)
  25. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Now THAT is a terrific idea......I think we have a solution....
