Front License Plate? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by The Ape, Apr 16, 2008.
  1. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
    So sorry if this thread is a repeat but I did a search and couldn't find anything. Anyhow, I got a fix it ticket for no plate and I need a solution on what the heck to do. I wont put on the bracket for obvious reasons. Anyone have the temporary fix?
  2. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    I carry the front plate inside the car along with some zip ties. If I get stopped I'll zip tie the plate to the car and have the cop sign it off then and there. If he refuses, then I'll go to the DMV the next day and get it signed off.
    Bob Wassam
  3. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,272
    Seattle Area
    Dave
    Good idea! I LIKE that one! I'll load some zip ties tomorrow just in case... Thanks!
    Jedi
  4. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    Just installed my "collector vehicle" plate today! No more regestration fees and only need to display the rear plate! (actually thats all they give you!)
    Cheers!
  5. Jedi
    Jedi Moderator
    Mar 18, 2008
    32,272
    Seattle Area
    Dave
    You DOG! If only I could make my '86 328 somehow appear as 30 years old or older!!!
    Good for you - in the meantime, I have to worry about the 'Front Plate Posse' getting me :)
    Jedi
  6. Rodriguez_Exotics
    Apr 9, 2008
    183
    this is why you move to arizona, no front plate required. :)
  7. conscom
    conscom Formula Junior
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Check out the Canada Front licence plate thread. I posted my solution to that problem with a simple solution. If you can't find it, PM me.
    Gary
  8. conscom
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Here's my solution: go to: Canada ---Vancouver owners...front license plate. I scanned the plate and plasticized it and then stick on front bumper with double sided tape. Also carried front plate in car and if asked would say, " I've ordered bracket" and hope to get away with it. Mostly, I stay away from areas where exotic cars congregate.
  9. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I just mounted the bracket and screwed the plate on. Simple
  10. maximus136
    maximus136 Karting
    Jul 17, 2006
    101
    latin america
    I live in Central America where front license plates are required........I took a picture of the plae had it made in reflective tape in original size, attached it wet, let it dry and it looks just like a regular plate!!!,I also carry the original inside just in case.......
  11. k-diddy
    k-diddy Formula Junior
    Oct 29, 2004
    530
    Stop in and I will let you use the custom front plate holder I have.
    Kevin
  12. marknkidz
    marknkidz Formula 3
    1,326
    so cal
    mark
    I saw the perfect solution on a 430 at local Baldy run we had couple weeks ago....(im sure you can find a photo of it on that thread, in so cal section)
    this 430 had a fabricated type holder that screwed into the front where you screw in the tow hook if you ever needed it (so you dont have to do anything to the car...it is already there!!). It would be so simple for any metal/welding shop to fabricate.
    Screw it in...get sign off. Unscrew...no muss no fuss..
    Good luck
  13. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,297
    do you HAVE to put it on or can you just pay a fine? if not, what are the consequences if you dont put it on?
  14. marknkidz
    marknkidz Formula 3
    1,326
    so cal
    mark
    Ok...found it, check out post #130 in the so. Cal. section "210 freway....."
    about the 3rd or 4th pic. down you will see a red 430 with the plate sticking out away from bumper.
