Front Lift | FerrariChat
Front Lift
Discussion in 'FF/Lusso' started by wings, May 15, 2018.
  1. wings
    wings Formula Junior
    Dec 13, 2003
    846
    On a 2017 F12 does anyone know how the front end suspension lift is powered? Is it all hydraulic, electric/hydraulic, or some other way. Cannot seem to get a definitive answer. Thanks.
  2. cayenne_ksa
    cayenne_ksa Karting
    Feb 7, 2007
    164
    denver, SAUDI
    i think its hydraulic with oil being used as fluid. i'm not 100% sure but why do you need such info. maybe i can help
  3. MDEL
    MDEL F1 Rookie
    4,040
    Southern Europe
    Mario
    That's the description of the F12 lift system. " The F12 Berlinetta has a front axle Superlift system - a system of hydraulic actuators driven pump powered by an electric motor and controlled by an electronic control unit making it possible to easily raise the vehicle and ride on uneven surface". As shown in the picture the system acts on the front shock absorbers.
  4. wings
    Dec 13, 2003
    846
    Thanks very much. I hope it is reliable. I have an all pneumatic system on my Huracan. First time I did not have all hydraulics. In the old days hydraulic lift systems were problematic. Leaks, plain failures,etc. Today they are more reliable however this is my first Ferrari with a lift system so I was curious as to how they worked. Also it is not a standard item. The option charge is North of $5000. Seems like a lot of cars do not have it. I needed it for a particular driveway that I have.
  5. MDEL
    MDEL F1 Rookie
    4,040
    Southern Europe
    Mario
    I have the lift system on my F12 and I can say it works very well. I only use it in special circumstances because the car height is more than enough to cope with most of the ramps, bumps etc.
  6. wings
    Dec 13, 2003
    846
    That's exactly what I do. Use it only when really necessary. Thanks!
    MDEL likes this.
  7. MedinaCustomClassics
    Dec 7, 2006
    210
    Medina, Washington
    Mark H
    It can be a life saver. I've got it on my FF. It also means you have the active headlights too
  8. GameMaker
    GameMaker Formula Junior
    Apr 17, 2014
    454
    WA State
    I have the lift system and I use it quite often. However, in almost all cases I think I could get away with it by being more careful, taking an angle etc. I do currently have this option on my superfast order as well, I think it's a good thing to have.
    MedinaCustomClassics likes this.
  9. ScottS
    ScottS F1 Rookie
    2,937
    Winter Park
    Scott S
    Have on my FF and F12. Lifesaver in some circumstances. Never want to hear that scraping noise ever again.
    It takes the parking uncertainty away when going someone I haven’t been.
    ScottS
  10. BruceC
    BruceC Formula Junior
    Apr 26, 2018
    258
    Tucson, AZ
    Currently shopping F12s - where is the dash control for the suspension lift? Most "used" listings don't state whether or not suspension lift is included and I haven't managed to spot it yet on any interior pics.
  11. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    Owners manual shows a small button near one of the central air vents - probably sort of behind the steering wheel
    BruceC likes this.
  12. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,581
    Grant
    #12 Wheels1, Dec 19, 2020
    I don't think you will be able to see it in most photos as it is hard to see.
    What might help is, the front lift had to come with the Adaptive Frontlight System so if the add says it has this then it may have the lift.
    The Adaptive Frontlight System became standard in the UK in 2016 but not sure if this is the same in the USA so it will not always be the case. Top button on the right, this is on a RHD car though.
    BruceC likes this.
  13. BruceC
    Apr 26, 2018
    258
    Tucson, AZ
    Grazie greyboxer & Wheels1! Very helpful. So frustrating to see tonnes of adverts that display extensive lists of unimportant technical details (e.g. disk brakes, ABS, etc) and don't bother to mention significant options. You would hope that exotic car dealers would be a little more knowledgeable.
