Front light Lifting question? | FerrariChat
Discussion in '348/355' started by i_love_cph, Jan 16, 2008.
  1. i_love_cph
    i_love_cph Karting
    Apr 26, 2007
    144
    MONACO
    #1 i_love_cph, Jan 16, 2008
    Yesterday when I turned on the front light on my 355, only the left one poped up.
    Question 1: Is it common that one of the lifting motors breakdown after some years of use?
    Question 2: Or could it just be a sudden disconnection between the leads?
    Thanx
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Probably a bad connection... those motors are pretty robust. I am not sure if each side has a separate fuse but I would look to find out...
  3. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,297
    each side has a separate fuse... check that first
    if it is in the same location as my 348 (under the front hood) it is the 2 7.5v fuses in slots 3 and 4
  4. f355spider
    f355spider F1 World Champ
    18,047
    Ditto, I blew a fuse recently for my right headlight motor, on a cold and dark night. I think the grease in that motor is getting stiff or something. Fuses for them are in the front trunk, left side, under the cover. Careful with all the knobs on the various covers, it is easy to drop them behind something.
  5. i_love_cph
    i_love_cph Karting
    Apr 26, 2007
    144
    MONACO
    Thanks guys! I will tjeck up on that.
    f355spider: Do you remember where they were located?
  6. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    There is a diagram (at least there is supposed to be a diagram) on the underside of the fuse panel cover in the front trunk, which shows the function of the individual fuses and relays. If your right headlight motor isn't working, check the fuse marked "Alzafaro DX" or "R.H. Headlight Motor".
    You should be able to manually raise the headlight door using the knob on the top of the motor. If the headlight will NOT raise using that method, then the linkage between the motor and the door itself has come loose. Sometimes the motor is turning correctly, but the linkage isn't moving. It's quite unlikely that the motor itself is at fault, but it's possible.
    Note: If you go to manually raise the headlight using the knob, be VERY careful that you don't get your fingers caught. Once the headlight reaches a certain point, the motor will kick in, and the motor is quite powerful. It's best to remove the fuse if you are manually raising the headlight.
    If the motor turns but the headlight door won't open, check nut #14 in your diagram to make sure it's tight.
