Front Lower Grill | FerrariChat
Front Lower Grill
Discussion in 'Chicago' started by Gerry328, Sep 11, 2007.
  1. Gerry328
    Gerry328 Formula 3
    2,442
    Home
    Gerry
    I just discovered the front lower grill on 328 has been painted. I believe the original finish is anodized black. What would be the cost to have this refinished? Are there any recommended places to have this work done?
  2. Dave Bendl
    Dave Bendl Formula Junior
    Dec 7, 2003
    807
    Chicagoland
    Dave Bendl
    Gerry,
    There are a number of plating shops in the Stone Park area. I have used one shop for black anodizing called All-Brite Anodizing Company a number of years ago. They are located: 3118 North Ave. Stone Park Ph. 708-681-4830
    Dave
  3. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    I'm not absolutely positive, but I don't think the 328 had a black anodized grille.
    I think it was natural stainless.
  4. Gerry328
    Gerry328 Formula 3
    2,442
    Home
    Gerry
    There are two front grills on the 328, the upper is natural aluminum. The lower is anodized black.
  5. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Ah yes, I forgot about that.
    The place that 'Dabe' used did a nice job
  6. Gerry328
    Gerry328 Formula 3
    2,442
    Home
    Gerry
    All Bright Anodizing has moved, and has a new phone:
    100 W. Lake St
    Norhtlake, IL
    708-562-0502
    I need to completely strip the old paint off the grill before taking it to them to re-anodize. They indicated that if any paint remains, the that area will not be anodized. Any suggestions on removing all of the paint?
  7. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    I'd try a chemical gel type, water soluable paint stripper.
    You can get it at any hardware or home improvement store.
    Also, you might check with Terrace Supply to see if they'd recommend something different. They are a supplier to body shops and have a few stores in the area.
