Front/Rear Weight Bias of 550? | FerrariChat
Discussion in '456/550/575' started by Grant, Jul 1, 2009.
  1. Grant
    Grant Karting
    Dec 4, 2003
    73
    Denver, CO USA
    Does anyone know the front to rear weight bias of the 550? I know the 612 and 599 have a rearward bias and wondered if the 550 shares that. I assume it's very close to 50/50, but wasn't sure.
    Thanks!
  2. tazandjan
    39,046
    #2 tazandjan, Jul 1, 2009
    Grant-Depends on who you want to believe and how much fuel is on board (30 gal x 6.5 ~ 195 lbs). Here are a couple of quotes:
    "All 550 Maranello's used a six-speed manual gearbox and variable back pressure exhausts similar to those previously seen on Ferrari's limited production F50. Weight distribution was split 50/50 front/rear and greatly contributed to the exceptional handling and balance dynamics."
    Spec.
    Front-mounted 48 valve 5.4 litre V12 engine
    Power: 480Bhp at 7,000rpm
    Top speed: 199MPH
    0-60MPH: 4.3 seconds
    0 - 100MPH: 11.2 seconds
    Weight: 3726lbs
    Weight distribution F / R: 52.5% / 47.5%
    Length: 179.3 inches
    Width: 76.18 inches
    Height: 50.27 inches
    From Motor Trend
    specifications
    ferrari 550 maranello lamborghini diablo 6.0
    general
    location of final assembly maranello, italy st. agata bolognese, italy
    body style 2-door, 2-pass. 2-door, 2-pass.
    epa size class mini-compact mini-compact
    drivetrain layout front engine, rear drive mid-engine, all-wheel drive
    airbag dual front dual front
    powertrain
    engine type 65o v-12, cast aluminum block and heads 60o v-12, cast aluminum block and heads
    bore x stroke, in./mm 3.46x2.95/88.0x75.0 3.43x3.31/87.0x84.0
    displacement, ci/cc 334.0/5474 365.7/5992
    compression ratio 10.8:1 10.7:1
    valve gear dohc, 4 valves/cyl. dohc, 4 valves/cyl.
    fuel/induction system seq. efi seq. efi
    horsepower, hp @ rpm, sae net 485 @ 7000 550 @ 7100
    torque, lb-ft @ rpm, sae net 419 @ 5000 457 @ 5500
    horsepower/liter 88.6 91.8
    redline, rpm 7000 7500
    transmission type 6-speed manual 5-speed manual
    axle ratio 3.91:1 2.81:1 (front)/2.41:1 (rear)
    final-drive ratio 2.96:1 2.71:1
    recommended fuel premium unleaded premium unleaded
    dimensions
    wheelbase, in./mm 98.4/2500 104.3/2650
    track, f/r, in./mm 64.3/62.4/1632/1586 63.4/65.7/1610/1670
    length, in./mm 179.1/4550 176.0/4470
    width, in./mm 76.2/1935 86.7/2200
    height, in./mm 50.3/1277 43.5/1105
    base curb weight, lb 3726 3582
    weight distribution, f/r, % 50/50 41/59
    fuel capacity, gal 30.0 26.4
    weight/power ratio, lb/hp 7.7 6.5
    Road and Track says 50/50 with driver and a half tank of gas
    Taz
    Terry Phillips
  3. Grant
    Grant Karting
    Dec 4, 2003
    73
    Denver, CO USA
    Thanks, Terry!
  4. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    I measured my Euro 01 at 1754 kg with a full tank of gas, 54.4% front, 45.6%, so the 50/50 claim is slightly ... romantic, as Ferrari's weight claims often are.
