Front registration plate advice | FerrariChat
Discussion in '458 Italia/488/F8' started by chatfer, Oct 8, 2025 at 1:39 PM.
  1. chatfer
    chatfer Rookie
    Nov 24, 2024
    41
    Hi All,
    So we need to run front here plates for the 458 in the UK - have purchased the carbonio bracket which arrived in super quick time.
    Any tips on where to stick the reg plate to the bracket? For maximum clearance I could fit lower edge of the plate to the bracket but I think this would cover the prancing horse emblem.
    I was planning to fit with the top of the plate to the top edge but this would likely lower the front clearance and risk grounding the front. Anyone have any pics of theirs fitted?
    Cheers.
    Maximum clearance - blocks the prancing horse.
    Lower clearance but won't block the emblem.
  2. 3POINT8
    3POINT8 F1 Veteran
    5,446
    We have to have front plates in Washington but its only like an $80 ticket so not worth putting it on the car. How bad do they drill you in the UK? Seems like a shame to mount a front plate on these cars.
  3. chatfer
    chatfer Rookie
    Nov 24, 2024
    41
    Wow $80, that would be worth the risk - in UK up to £1,000 fine and they may also take the registration off you for repeated offences.
    Agree - looks better without plates but at least the carbonio can be easily removed.
  4. Zarakoff
    Zarakoff Karting
    Jul 8, 2020
    207
    Uk
    Ian Curley
    Keep the plate in the front under the seat . I got pulled once for no front plate
    They flashed me down i quickly put the plate in the front window . And said I’ve just had ppf done and need to leave it off for a few days they were fine with that in uk
