Front spindle color: natural (cast) or painted? | FerrariChat
Discussion in '308/328' started by Dan Harris, Aug 1, 2024.
  1. Dan Harris
    Dan Harris Rookie
    33
    Daniel Harris
    Hello All,
    I'm restoring the front suspension on my 308 QV, and it's not clear to me if the front spindles were originally painted. Are these meant to be painted black, or are they natural color?
    Thanks in advance and have a great day All!
  2. jhh925
    jhh925 Karting
    72
    Reno
    Jens
    Slightly different car (1987 328), but mine were painted black.
  3. Dan Harris
    Dan Harris Rookie
    33
    Daniel Harris
    Great info, thanks. Was it gloss or semigloss?
  4. jhh925
    jhh925 Karting
    72
    Reno
    Jens
    Well, it was hella dirty. Though, of course, that's not a helpful reply. I've stripped mine at this point, but going off of memory, it was satin or semi-gloss. Not gloss.
    Edit: Not sure if this is helpful to you, but in my 328 restoration, my current plan is to use VHT engine block paint (black) because I am treating that part as a high-temp application. As a result, whatever the paint used to be, I'm assuming I'll end up with gloss black.
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    '85 QV, all original. Black. I wouldn't call it flat, but not semigloss either. Looks like about the same as the black on the frame in the engine compartment.
  6. Dan Harris
    Dan Harris Rookie
    33
    Daniel Harris
    Thanks, @JohnK and @jhh925. I'll probably go with Eastwood semigloss chassis black then.
    Steve Magnusson likes this.
  7. 4right
    4right F1 Rookie
  8. Dan Harris
    Dan Harris Rookie
    33
    Daniel Harris
    That’s brilliant, thanks!
  9. Imatk
    Imatk Formula Junior
    May 6, 2007
    765
    On mine the arm was silver and the knuckle was black
