Front Springs 308QV | FerrariChat
Front Springs 308QV
Discussion in '308/328' started by RallyBart, Mar 26, 2025.
  1. RallyBart
    RallyBart Rookie
    Feb 1, 2019
    2
    Bart
    Hello, when restoring the 308QV '85 I removed the front shocks and took out the Kona schockabsorbers.
    Then a saw that the left spring is about 1inch (2,5 cm) shorter than the right one.
    Is this normal with a Ferrari?
    And if not, what can be cause?
    New spring?
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,808
    Cerritos, CA.
    Definitely not normal They should be equivalently even, I know the euro car springs are shorter than the US car. But I think it’s totally different Springs because the one on the left has 12 coils and the one on the right only has 11 coils
  3. Steve Magnusson
    26,781
    Fronts and Rears are also different free lengths (we just had a case of a 328 getting wrongly assembled with the longer rear springs used at the front: https://www.ferrarichat.com/forum/threads/1986-328-gts-front-ride-height-too-high-after-full-rebuild.703550/#post-150020599). Or maybe the car had one spring replaced and someone wanting a front spring got sold a longer rear spring. Front and rear springs are actually matched in pairs side-to-side for having a certain load at the working length so the free length may be slightly different -- but not 2,5 cm different.
  4. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    Perhaps you should compare the rear pair of damper/springs and see what they look like.
  5. MaranelloMark
    MaranelloMark Formula Junior
    438
    Bay Area, CA
    It’s hard for me to see the difference in turns (coils). Looks the same to me. One is rotated a little. And the one on the right looks like it has some preload? The spacing between the coils is different which makes me think one has some preload or the damper is binding.
  6. miketuason
    Feb 24, 2006
    15,808
    Cerritos, CA.
    Count from the bottom coil to the top, you can clearly see the numbers of coil
    Steve Magnusson likes this.
  7. Imatk
    Imatk Formula Junior
    May 6, 2007
    767
    Yep that is... not correct sir
  8. Dr Tommy Cosgrove
    36,425
    Birmingham, AL
    Tommy
    That's insane on a car being used.
  9. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    407
    Pacific Northwest, USA
    Dave W
    The shock on the right does look more compressed to me. I don't know if it's 2.5cm lower, but compare the bottom of the "dust boot" on both shocks.
    - Dave
    MaranelloMark likes this.
  10. Imatk
    May 6, 2007
    767
    That shock is probably just less tired than the other one.
    When I put in new Konis... those suckers open up with just a little gravity, unlike the ones I took off which were basically not moving at all unless you pulled on them.
