Front suspension rattle | FerrariChat
Discussion in '360/430' started by fusion, Dec 13, 2009.
  1. fusion
    fusion Rookie
    Dec 13, 2009
    3
    Hello all,
    I am new to this forum as I have only recently purchased a 360 spider ( 2004 ) with 11,000 miles on the clock.
    This is my first Ferrari and it is awesome !!!
    As the roads aren't great where I live i have developed a rattle on the passenger side front suspension. It is loud and can be heard when going over small potholes etc.
    Can anyone tell me what it is likely to be ?
    Thanks,
    Fusion.
  2. CyclingPeaks
    CyclingPeaks Formula Junior
    Jun 11, 2006
    361
    Big Island, Virginia
    Hunter Allen
    Could be anything related to the suspension. Lose nut on the shock, coil is broken, tie-rod is loose, anything. Get it checked out asap.
    I had a rear coil break on me on my M3 and only knew it because I went over a speed bump and heard it clang. Then put it up on my stands, pulled the rear wheel and the damn coil just fell right out.....
    Hunter
  3. Taffy
    Taffy Karting
    Mar 30, 2007
    114
    Cardiff UK
    Chris T
    Sounds like a lower wishbone ball joint.....common wear item on the 360.
  4. Derek Trotter
    Derek Trotter Formula 3
    1,790
    Cambridge, UK
    Sounds like it. If they do need replacing, go for the Hill Engineering replacements, they should never fail again.
  5. fusion
    fusion Rookie
    Dec 13, 2009
    3
    Thanks lads.
    I'll take her to the mate's garage and put her on the ramp to see what the problem is.
    Thanks Derek for link for balljoint supplier.
    I'll keep you posted once we've checked it out.
    Regards,
    Fusion.
  6. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Could be one of the following:
    Anti roll bar end link rubber bushings
    A arm bushings
    Ball joints
    Damper bushings
  7. Derek Trotter
    1,790
    Cambridge, UK
    BTW, you can buy the Hill Engineering parts from Daniel at Ricambi if you're that side of the pond.
  8. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,892
    My 360 also suffered from front suspension rattles and creaks.
    There was a campaign to replace some of the bolts with teflon coated ones. I had this done and the creaks went away for a few weeks, but then came back!
    No one who looked at the car was ever able to identify a problem.
    Eventually after 40K miles, the sounds just went away by themselves.
    Now I have noticed squeeking noises from the rear suspension!
  9. Andy T
    Andy T Karting
    May 31, 2004
    56
    Sheffield - England
    Andy
    I had the entire suspension on my '99 360 rebuilt - top and bottom ball joints, track rod ends and inners - guess what - still rattled!
  10. fusion
    fusion Rookie
    Dec 13, 2009
    3
    DT gets first prize !
    Put the car up on the ramp and it shows wear to the bottom balljoint.
    Ordered one from hill engineering.
    Thanks again for all your input
    Fusion.
