Front underbody cover '72 246GT | FerrariChat
Discussion in '206/246' started by cls, Aug 21, 2019.
  1. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    Does anyone make a cover for the front, under the steering rack? Looks like six machine screws hold it in place. I checked all the usual sources and no one seems to make it. Although I'm sure I can make it myself, spending that much time under the car doesn't sound like fun, so I'd rather find one ready made.
  2. racerboy9
    racerboy9 F1 Rookie
    2,645
    I'm in the same boat on those covers and need two. They were fiberglass at least on the later cars. I have instructions for making one someone posted on F-Chat and it looks pretty simple. Just a matter of having the time.
  3. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
  4. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Correction - that plate I referred to looks to small.
  5. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Yes, I think that's the plate that fits in the trapezoidal front piece 24603055.
  6. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Chris
    Just checked with SF and the part I referred to is 245 x 145 approx. so you are right, its not the part.
    My plate measures 535mm x 460mm x 16 SWG, should be easy to get someone to cut it for you. Did a search over in the UK and they want about £10 for a piece made to measure.
    Tony
  7. racerboy9
    racerboy9 F1 Rookie
    2,645
  8. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    That's very helpful. I am going to send this info to alberto, @swift53 and have one fabricated. If you want two made,racerboy9, I can have him make them and send one over. I owe you anyways.
  9. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Haha, that’s my sketch off my L-series
    Should be correct....
  10. racerboy9
    racerboy9 F1 Rookie
    2,645
    Aha! Thanks for that Andrew. I think I will fabricate one out of aluminum first and trial fit it as I have and E series. If it works out I will use it for a mold for fiberglass.
    dgt likes this.
  11. swift53
    swift53 F1 Veteran
    8,286
    E.S.
    Alberto
    Well, I checked for mine bottoms, and none to be seen. Dino E, 03724.
    Will have to make whole bottom.
    Ally or Glass?
    Regards, Alberto
  12. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Every one I have seen that looks original is fiberglass.
  13. swift53
    swift53 F1 Veteran
    8,286
    E.S.
    Alberto
    It would be easy for you as fiberglass sheets are sold in the USA, not here.
    I would have preferred ally, as easier, but if I have to, I will hand lay the glass.
    Regards, Alberto
