Front Wheel Bearing Failure | FerrariChat
Discussion in 'Mondial' started by nino calamita, Apr 30, 2013.
  1. nino calamita
    nino calamita Karting
    Sep 21, 2011
    158
    Chesterfield, UK.
    Emanuel Calamita
    At long last here in the UK there appears to be 2 days of decent weather strung togerther enough to drive my Mondial but on doing so I detected a strange noise coming from one of the front wheels. This as it turns out was the wheel bearing falling appart and nearly seized up. Upon removal and stripdown it appears that both the plastic ball cages have broken probably due to becoming brittle with age. Anyone else had this problem.
    Nino
  2. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Front wheel bearings are usually tapered rollers ... Do Ferraris use ball bearings, weird?
    Pete
  3. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,794
    Essentially everything (even F) after the early~mid 1980s uses the double-row (monolithic) ball bearing at the front -- so you are dating yourself ;)
  4. Steve Magnusson
    26,794
    I just did this on my TR at ~67K miles (which uses the same bearing) and the cages seemed OK (but the bearing was "dry" enough to where any further use probably wouldn't have done it any good) -- of course, I wasn't going to do any "flex" tests to the cages ;). You can see one of the cages in the background of this photo -- it's sort of a double cage that keeps the two ball row sets staggered by 1/2 pitch:
    How many miles on your Mondial bearings? If you do a search on the F PN "112799", you should get some prior threads that you may find useful.
    TR front hub assembly after cleaning/repacking/reassembly:
  5. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Not so on Toyotas, or at least the ones I've worked on ... rear wheel drive ones anyway.
    Weird as taper roller surely superior ... ?
    Pete
  6. Steve Magnusson
    26,794
    Depends how you define "superior" -- for absolute strength (like hitting a curb over-and-over), the tapered roller bearings probably are better, but the monolithic double-row ball bearing can't be mis-assembled (at the car assembly plant), nor have the wrong preload at assembly, and it is a much more compact design far better suited to modern chassis layouts using large positive wheel offsets (i.e., to use the tapered cylindrical roller bearings efficiently needs a wheel design, like the 308, with the center projection sticking out -- modern wheels have a more-flush outside surface to reduce drag).
    PS I wrote "essentially everything", not "absolutely everything" ;)
  7. Valenzo
    Valenzo F1 Veteran
    Dec 4, 2010
    5,069
    IL & NC
    Ted
    Niño, what was the "weird sound"? A rattle, a squeal or a squeak?
  8. nino calamita
    Sep 21, 2011
    158
    Chesterfield, UK.
    Emanuel Calamita
    It was more of a droning sound which got more progressive the higher the road speed.
  9. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I just had my rotors off and didn't do the extra step as I was out of time. Guess I may pull it apart again this weekend and take a look at what's going on in there.
    Thanks Nino for reminding us.
    I've had a tech say he's never seen a failure of these bearings in a regularly used vehicle, but that was 4 years ago and they get older every year. 25 years with no new grease is a long time.
  10. nino calamita
    Sep 21, 2011
    158
    Chesterfield, UK.
    Emanuel Calamita
    The thing is with this type of bearing is that it can be quite easy to take appart and repack with new grease, something really that can be done on a regular basis. Once it fails it can prove quite expensive, Eurospares quote £600 in total. Ordered mine from my local supplier Spire Bearings in Chesterfield for the sum of £60 total and it is a genuine origional SKF bearing. Will post pics later this evening.
  11. nino calamita
    Sep 21, 2011
    158
    Chesterfield, UK.
    Emanuel Calamita
  12. Steve Magnusson
    26,794
    That's a fantastic low price -- was your SKF supplier able to provide it just by using the 441996R part number marked on the race (and did your old one have the same marking)?
  13. nino calamita
    Sep 21, 2011
    158
    Chesterfield, UK.
    Emanuel Calamita
    yes it was all done via the SKF part no.
  14. ace_pilot
    ace_pilot Formula Junior
    Sep 6, 2007
    921
    Long Island, NY
    George
    Any step by step DIY for removal of the bearings? Sorry I didn't do a search.
    Ace
  15. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    Wheel bearings are in my TBD list. I replaced the front rotors but did not have enough time to repack the bearings. Done by the PO a few years back.
    Per the pictures shown in this thread, and in the Ricambi parts list, I do not see a seal. Is there one that I need to replace when repacking them?
  16. nino calamita
    Sep 21, 2011
    158
    Chesterfield, UK.
    Emanuel Calamita
    sorry no step by step removal pics but it is very straight forward to remove the bearing. Regards the seal on the bearing if you look at post #4 you will notice that in the 1st pic there is a seal on the outer race but in the 2nd pic there is no seal. When the bearing is bolted in place on the hub it fits in a way that a seal is not needeed. Note that the TR bearing does not have an ABS ring where as the Mondial has one at the back of the bearing.
    Nino.
