Front Wheel Bearings | FerrariChat
Discussion in '206/246' started by patrickvela, Jul 13, 2011.
  1. patrickvela
    patrickvela Rookie
    Sep 13, 2008
    16
    Has anyone got a "rule of thumb" set up for the front wheel bearing play? I've just driven 1000K across Spain and am suspicious they have too much play in them. I know NOT to over tighten them, but I can feel movement on both front wheels when pushing them. I've got 1000K return trip next week so don't want to damage anything!.
    Thanks.
  2. swift53
    swift53 F1 Veteran
    8,286
    E.S.
    Alberto
    #2 swift53, Jul 13, 2011
    Unless you can get a dial indicator, and do 3-4 thou play, just tighten the castellated nut
    an 1/8 + of a turn.
    This, is strictly hit and miss, as not the proper way of adjusting, but in an emergency....
    Regards, Alberto
  3. patrickvela
    patrickvela Rookie
    Sep 13, 2008
    16
    Thanks Alberto,
    do you think I should still feel some play in the wheels when tightened or should they feel snug?
  4. swift53
    swift53 F1 Veteran
    8,286
    E.S.
    Alberto
    Patrick, freewheeling but without side to side movement, if with the tire on. If you are really concerned and doing the adjustment yourself, it possibly could be better if you stopped by any small mechanical shop. They will know what to do as long as you do not lose sight of the car...
    Regards, Alberto
  5. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    Inpect outer bearing race as they are known to gaul and pit. Inner race requires removal of grease seal and new seal installed. No play must be felt
    clay
