Front Wheel Bearings | FerrariChat
Discussion in '308/328' started by [email protected], Mar 8, 2020.
  1. mxstav@comcast.net
    Nov 24, 2005
    212
    Green Oaks, IL
    Mark Stavropoulos
    I am in the process of rebuilding the front suspension and steering on my 308. I noticed the front outer wheel bearing race has vertical grooves in it. They appear to be precisely regular and can be felt with one's finger, so it is not just a marking. What would cause this? I notice the race is and SKF Italy part and the wheel beariing is a Timken USA part. Evidently the bearing was replaced at one point but not the race. Should I replace the set? See the attached photo's. The other side looks fine and are both Italian parts.
    Grazie
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Bearings should always be replaced as a set.
  3. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
  4. Rifledriver
    37,288
    They're cheap. Buy a whole set.
  5. mxstav@comcast.net
    Nov 24, 2005
    212
    Green Oaks, IL
    Mark Stavropoulos
    Thanks for the informative links and suggestions. You guys are right. They are cheap enough just to replace the entire set. I may as well do both sides.
    waymar likes this.
