Frustrated! Need some help brothers | FerrariChat
Discussion in '348/355' started by md0811usmc, Aug 12, 2007.
  1. md0811usmc
    md0811usmc Karting
    Feb 21, 2006
    75
    Reading, Pa
    Marco Decamillo
    For the past few days my car has been acting sick. Everytime I start it it sounds fine, but when I come to a red light or stop sign it stalls, the rms are fine at idle 1000, but drop at stopping and stalls. Then it starts to make a fluttering sound, but no cels or sdl. It sounds like a hole in my exhaust but everything looks ok. It revs up really rough like a hole in the exhaust and very rattly sounding. I disconected the battery for 10 min and started it back up and same thing. I cleaned the conections on MAF. It goes in tomorrow for the 30K service, is there anything I should look for or have my mechanic look for, this is driving me nuts. I have a 1991 with BMC filters, hyper flow cats and a xost level 2 exhaust. Thanks.
  2. Ricambi America
    Sponsor Owner
    #1 Do the CEL and SDL at least illuminate when the key is on the accessory position? Let's make sure the bulbs are there, first.
    #2 cleaning MAF's can be very problematic unless you use proper cleaner and absolutely don't touch anything. They're pretty delicate.
    #3 When you're driving the car, does it still have full power, or does it feel like only 1/2 the power is there?
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    http://www.club348.com/technical/Tech/348.html#EngineStallsOverheats
    Stalling when you come to a complete stop, but having good idle RPMs and otherwise running fine, is typically due to idle air bypass passages needing cleaning or idle air bypass screws needing opening a bit.
    Stalling when you come to a stop but rough running engine at othertimes might be a clogged cat or air intake, among other things.
  4. md0811usmc
    md0811usmc Karting
    Feb 21, 2006
    75
    Reading, Pa
    Marco Decamillo
    All cel and sdl come on fine at start up. It just started doing this, but a month ago my drivers side cat was glowing red hot and I was told by another F chatter that his 348 did the same thing and it turned out to be a bad coil pack not firing one of the cylinders. I am just worried that I will not be able to get my baby to the mechanic about a 20 minute drive.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Even if you have a clogged cat making your car stall at idle and rev rough, you still need to know what caused it to fail in the first place. Hyperflow cats don't just go bad.
    Fitting a new cat without fixing the core problem would just see a repeat.
  6. md0811usmc
    md0811usmc Karting
    Feb 21, 2006
    75
    Reading, Pa
    Marco Decamillo
    Turned out to be the ignition pack or spark plug coils
  7. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Congrats on your fix!
  8. GQ IMAGE
    GQ IMAGE Formula Junior
    Feb 10, 2005
    322
    PA
    GQ IMAGE
    Who is doing your 30K service in Reading PA?
