For Sale - FS: 458 15mm 20mm spacers & Titanium Wheel Bolts | FerrariChat
For Sale FS: 458 15mm 20mm spacers & Titanium Wheel Bolts
Discussion in 'Ferrari Parts & Collectibles' started by v35, Aug 25, 2019.
  1. v35
    v35 Karting
    May 15, 2013
    190
    Los Angeles
    Aaron
    Selling my hardly used 15mm and 20mm spacers with extended length titanium wheel bolts. These are the perfect widths to get the most ideal look with the stock wheels without any rubbing.
    Information about the spacers:
    “Focusing on quality and safety Exotic Car Gear offers alloy spacers are produced from a T6 7075 Aluminum alloy with an Anodized finished for increase strength. T6 7075 Alloy provides twice the tensile strength of the T6 6068 widely used in the market. Exotic Car Gear’s Hub Centric wheel spacers insure the wheel remains properly centered and the load supported with an exact fit.
    1. Forged and CNC Machined from aircraft grade Aluminum Alloy T6 7075
    2. Precision Engineered Hub-Centric and Model Specific for Perfect Fit and Wheel Balance.
    3. Heat Tempered for Increased Strength and Durability.
    4. Hard Anodized Finish for Durability and Corrosion Protection.
    This set also comes with a set of extended length Titanium wheel bolts that are fitted to work with the spacers as well as save weight over the stock bolts.
    Ferrari Challenge Style Titanium Wheel Bolts, Polished Finish
    Will fit all OEM standard wheels.
    Wheel Bolt heads are Hot Forged for higher strength -vs – machined head
    Rolled threads for greater fatigue resistance and avoiding galling –vs- cut threads.
    Exact match to the OEM wheel bolts for the current Ferrari models. Same bolt design Ferrari offers for the 458 Speciale and F12 @ $280.00 per bolt.
    This Product Purchase Includes:
    Material: Gr5 (Ti-6Al-4V)
    Tensile Strength: 900~1050Mpa ( 130,000 – 152,000 psi )
    Size(mm): M14 X 1.5 X 50mm
    DIN 912/933/7991/7984/6921, ISO 7380, JIS, BS
    Recommended Dry Torque Setting: Please Refer to Vehicle Manufactures Specifications.
    Weight:
    OEM Spec Steel Bolt: 128 grams
    OEM Spec Ti Bolt: 63 grams
    50% Percent weight savings over “stock” steel bolts:
    Price for Entire set:
    $900 shipped in the 48 states with tracking
    Payment via PayPal
  2. kimwizzzuuu
    kimwizzzuuu Karting
    Aug 26, 2018
    240
    new york
    Kim
    How much for bolts alone without spacer?
  3. PCJR
    PCJR Formula Junior
    253
    PA
    Exotic car gear sells the bolts separately.
    These would be too long if you didn’t use the spacers. I have them on my 458
  4. kimwizzzuuu
    kimwizzzuuu Karting
    Aug 26, 2018
    240
    new york
    Kim
    I’ve ordered Novitec spacers for my speciale, so I need extended bolts.
  5. v35
    v35 Karting
    May 15, 2013
    190
    Los Angeles
    Aaron
    Would like to sell the spacers and bolts together. Exotic auto gear sells the bolts separately in different finishes (black,polished, satin)
  6. v35
    v35 Karting
    May 15, 2013
    190
    Los Angeles
    Aaron
  7. kimwizzzuuu
    kimwizzzuuu Karting
    Aug 26, 2018
    240
    new york
    Kim
    let me know if you ever willing to parting the bolts alone. Thanks
    v35 likes this.
  8. v35
    v35 Karting
    May 15, 2013
    190
    Los Angeles
    Aaron
  9. Nexxas
    Nexxas Rookie
    Jul 15, 2019
    36
    Orlando, FL
    Fabian Alexander
    V35, how did you have your 458 lowered? Looks sharp
  10. v35
    v35 Karting
    May 15, 2013
    190
    Los Angeles
    Aaron
    thanks, lowered on Novitec springs
  11. Gabriel Speaks
    Jan 17, 2018
    3
    Gabriel Speaks
    Do you know where I can find novitec wheel spacers with bolts? Front and rears
  12. joseph
    joseph Formula Junior
    266
    New Jersey
    Will these fit on an F12?
  13. mrchaztsai
    mrchaztsai Karting
    102
    Hong Kong/Los Angeles
    Charlie T
    I have a set available, 15mm and 20mm with titanium studs. New wheels ended up arriving before I could use them with my OEM wheels. Brand new just opened the box to check the contents.
  14. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,193
    Orange, Calif
    Can you PM me with pictures and price please ?`
  15. mrchaztsai
    mrchaztsai Karting
    102
    Charlie T
    PM'd
  16. WorKeDiT
    WorKeDiT Rookie
    Dec 9, 2021
    13
    VA
    Melvin M
    Did these sell? Interested, thanks.
  17. joseph
    266
    New Jersey
    That’s not my post you got the wrong person
