Fuel Cap Not Opening | FerrariChat
Discussion in '612/599' started by JM280z, May 7, 2022.
  1. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    852
    Jake
    2007 599.
    Fuel cap not opening with the cabin button when engine is off and car is in on position or when engine is on.
    I checked the 10amp fuse and looks fine.
    Any common causes of failure with this?
  2. windsock
    windsock Formula 3
    1,129
    Really common for them to get corrosion from washing and lack of use in long storage. There is an emergency release in the trunk, it will be a red string.
    Once open it may stick open until you get WD40 or equivalent to clean it up.
  3. JM280z
    Aug 22, 2020
    852
    Jake
    The yellow/white plastic retention thing doesn’t actuate from the button
  4. Skidkid
    Skidkid F1 Veteran
    9,493
    Campbell, CA
    John Zornes
    It sounds like you are saying in the on position. The answer is that it does not open in the on position. Turn key off and it will open.
    Hawkeye and JM280z like this.
  5. JM280z
    Aug 22, 2020
    852
    Jake
    Haha, so my f430 requires the car to be on for the cap to open. For the 599 the car has to be off. Nice! Forgetting easy things is what happens after 5 months of storage apparently
  6. FerrariFinally
    FerrariFinally Formula Junior
    Nov 11, 2018
    558
    Roseville, CA
    Kevin
    I know old thread, but having same issue with gas cap. I will have to try with key in ignition in the off position.
    Just too many different makes and models and functions...I have been pulling the red string in the trunk for a while...although it doesn't get fill ups that often
  7. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,744
    Weston, MA
    Paul
    Try this, with the key fob lock and unlock the car 3 times. Don't rush it, take 2-3 seconds between functions.
    BTW, this can sometimes also solve the trunk failing to open. It's worked on both my 612 and FF.
    bay likes this.
  8. bay
    bay Formula 3
    Mar 13, 2011
    1,268
    Belgium
    Bernard
    Nospinzone likes this.
