Fuel cell question | FerrariChat
Fuel cell question
Discussion in 'Technical Q&A' started by Crowndog, Jan 25, 2014.
  1. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    How does a fuel gauge work in a fuel cell?
  2. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Usually, instead of a lever actuated float (as in a street car), there are cylindrical floats or resistor level sensor "columns" bolted onto the top plate. Like this one: http://image.customclassictrucks.com/f/techarticles/1304cct_1968_chevrolet_c10_camaro_gas_tank_install/43931456/1304cct-04-o-%2B1968-chevrolet-c10-camaro-gas-tank-install%2Bfloatless-fuel-level-sender.jpg
    The lever action floats move around too much when the fuel is sloshed around and do not allow for the foam (which dampens that slosh) to be used, so you cut a "column" in the foam vertically and install one of these floatless senders, making sure of the seal on the header plate of the fuel cell.
  3. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Thank you. I wish I had one if those in my car instead.
  4. fatbillybob
    Aug 10, 2002
    28,980
    socal
    Most use a wooden stick
  5. GTS Bruce
    GTS Bruce Formula Junior
    Oct 10, 2012
    804
    Orchard Park NY
    Bruce Roche
    Remember stick the tanks on boats? Hell they still stick the tanks at gas stations.
  6. vrsurgeon
    vrsurgeon F1 World Champ
    16,526
    Charleston, SC
    Curt
    Love it! That way you KNOW the true level..
