Fuel consumption shocker | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by aidanparte, Aug 28, 2007.
  1. aidanparte
    aidanparte Formula 3
    Jul 18, 2004
    1,231
    I got 8 miles per US gallon on my last tank (323km on 25 gallons). There was some highway, some town driving. There is not a hole in the tank, before anyone asks!
    How bad are your cars on juice?
    Aidan
  2. Fritz Ficke
    Fritz Ficke Formula 3
    2,266
    Tucson, AZ.
    Fritz Ficke
    I have not tested city driven, but in my 400I I got 11 MPG over 80 MPH under 100 ( some spike's higher) and I have gotten just under 14 MPG if I can keep it below 80MPH.
    I am curious what the carbed cars get becouse I really like the sound and power of the carbed engine over the CIS engine (although I really like the seamless refined power of the CIS) but did worried about fuel consumption and some other things.
  3. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Hey Aidan,
    On Ferrari Club of America's technical forum, someone mentioned that in the 400i instructions (whatever that meant) fuel consumption was listed @ 12/14 miles per imp. gal., or about 10/12 per US gal.. Are you lighting up the tires, maybe running a little rich (pull a plug on ea. bank), if a little rich---Dave has mentioned to lean out the mixture (counterclockwise) w/ 3mm T-handle hex wrench (a gas sniffer up the tailpipe wouldn't be a bad idea either to bring CO levels w/in range) on the fuel distributors.
    Bruce
  4. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    I used to get between 10 and 11 with her Aidan.
    Did Bill make some adjustments? Or are you over-enjoying the sound from the new exhaust?
  5. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Maybe he's drifting!
  6. Ray F
    Ray F Karting
    Jul 17, 2005
    192
    Somerset, England
    Ray Forster
    My '77 carburettor manual gets 11 mpg (Imp) on standard, mixed fast (80 mph) & town, driving - less, into single figures, if I step on the loud pedal too much.
    Keeping the Faith,
    Ray.
  7. aidanparte
    Jul 18, 2004
    1,231
    Bill did a lot of work optimizing the fuel injection as part of the major.
    I haven't been driving too wildly - my 3-year-old loves me to give it some welly, though. I've been keeping it in second gear quite a bit when pottering around, though.
    Still, it is quite shocking. A while back, I did some carbon offsetting (through Native Energy) to lessen the guilt factor when driving it.
    Aidan
  8. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Aidan, I do the exact same thing to keep the revs up vs. grandma-ing it around, and this is why your mileage is down a little. I also notice h2o can run a little high during this time as not enough air passing thru the rad, but once up to speed, temps @ 12 o'clock. Ferraris are designed to run flat out 24/7.
  9. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Car & Driver road tested a 400i in their December 1982 issue. This was a privately imported example, converted by Amerispec, with a 5-speed. In their test results chart, they list "Fuel Economy, EPA city driving", as 8 MPG.
  10. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    I've been getting 12 to 14 mpg. I did a good check of the odometer and these need to be corrected only about 3% down. I have only done one trip since getting the timing and CO adjustments corrected and I got about 14 on that trip.
    I need to drive it harder!
    Ken
  11. ricar116
    ricar116 Formula Junior
    Aug 2, 2005
    409
    Bolivar, Missouri
    Rick Carr
    What would be interesting would be to get on a chassis dyno with a wide band O2 sensor and really tune timing and fuel. Plan to do this on my carbed car when I get the motor back in. Overly Rich makes rings/cylinder walls last not so long. Then check the mileage. Don't get me wrong not to tune it lathargic but maybe low 14 to mid 13:1 (air fuel ratio). Has anyone on this board done this?
    Rick
  12. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    Set mine up using the sniffer at a local garage. 1.75% CO on both sides. The factory setting is between 1 and 2%.
    Runs like a scalded dog when I lean on my right foot.
  13. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    GO KEN!! Sunday sunrises are a blast!
