Fuel door and Trunk door not working on 599 | FerrariChat
Discussion in '612/599' started by phil the brit, Jun 3, 2021.
  1. phil the brit
    phil the brit Formula 3
    Jul 7, 2013
    1,215
    Colchester+Clermont
    Phil Taylor
    My 599 fuel door and trunk doors both inoperative. Both work fine with pull cables. As 599 owners will be aware both switches have their own little panel on the drivers side floor. For both to go wrong at same time seems strange. Any ideas anyone?
  2. Rex71
    Rex71 Formula Junior
    Mar 24, 2007
    359
    Jeddah,Saudi Arabia
    Majd B.
    Try this, it might work.
    George Vosburgh likes this.
  3. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,251
    Indiana/North Carolina
    JIM
    Happened to me a few weeks ago. The above method worked. If it doesn't, disconnect the battery master switch (in the trunk) with the car OFF. Wait 1 minute, re-connect the switch then start the car and let it run through it's checks. Should remedy it.
  4. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,112
    Atlanta
    Tom Spiro
    when you do this - its does take some time for the car to relearn all its parameters... trunk will not work for a bit.. drive the car for 20 min then systems should be on line.
  5. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    939
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    I have experienced the same thing and then it self corrected.
  6. phil the brit
    Jul 7, 2013
    1,215
    Colchester+Clermont
    Phil Taylor
    Absolutely brilliant guys, worked perfectly for both switches. Many thanks for the information.
    Just out of curiosity, how the heck are we meant to know this stuff. thank heavens for the forum.
    George Vosburgh and Rex71 like this.
