360 - Fuel Filler Cap | FerrariChat
360 Fuel Filler Cap
Discussion in '360/430' started by JonM, Jan 26, 2021.
  1. JonM
    JonM Karting
    Oct 31, 2017
    132
    South Gippsland, Victoria, Australia
    Jon Maratos
    Hi brains trust. Every time I fill up with petrol (gas), after unscrewing the cap, I have to then remove what looks like a seal that's stuck in the neck of the filler. I don't have another one to compare it with, but should the cap be in two pieces or should there be some sort of clip or something that holds the inside "seal" bit to the actual cap? I don't want to order a replacement if this is how it's meant to be or there's a way to fix this one. Thanks, Jon Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. modificator
    modificator Formula Junior
    438
    Florida
    George
    The cap should be one piece, it has split into 2 in your case. You can also glue it back together - just make sure to do it only around the edges and not to cover any of the tiny holes in both parts - covering them can give you the CEL
    Need4Spd likes this.
  3. JonM
    JonM Karting
    Oct 31, 2017
    132
    Jon Maratos
    Thanks, lots of places to buy. My go to place is Eurospares in UK, but usually look at who has the best price. More trying to work out if it should be like this or is broken. It's been this way for the 3 years I've had the car and no CEL from it. Just annoys me every time I fill up.
  4. JonM
    JonM Karting
    Oct 31, 2017
    132
    Jon Maratos
    That's great to know thanks. I presume I could use some sort of fuel-safe silicone to glue it back together?
  5. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,947
    Melbourne Florida
    KGC
    Mine has split too. Been like that for 3 years now. When I got the car I filled it up with gas once and didn't cinch the cap down super tight and got a CEL. Since then I torque it down as tight as I can with my hand. No other CELs since. Cost of a new cap ( a part that doesn't even show) has put my purchase on hold since all is well.
  6. hessank
    hessank Formula 3
    1,921
    Canada, Florida
    Fred
    Mine too.
    I used a Permatex fuel resistant epoxy.
    Been 4 years now
    Need4Spd and JonM like this.
  7. JonM
    JonM Karting
    Oct 31, 2017
    132
    Jon Maratos
    Do you remember which Permatex product you used? I'm having trouble working out which of their numerous products would be the right one.
  8. proggero
    proggero Rookie
    Apr 18, 2013
    25
    San Francisco
    Paul Roggero
    I used a product called JB Kwik from JB Weld. Used about fours years ago. No CEL issues.
    JonM likes this.
  9. daniellove304
    daniellove304 Rookie
    Jan 5, 2020
    17
    Marietta Ga
    Daniel
    Does not hurt to try. But i would buy one new its not that expressive
  10. hessank
    hessank Formula 3
    1,921
    Canada, Florida
    Fred
    Sorry for my error. My son had taken it from me to fix something on his car.
    He said it was Loctite (no affiliation), the picture is attached.
    "...... Loctite® Epoxy Weld can be used as a convenient alternative to welding. ... Loctite® Epoxy Weld does not shrink and is resistant to most shop fluids such as water, diesel fuel, gasoline, antifreeze, hydraulic fluid, motor oil and transmission fluids. ... Build. Construction Adhesives........"
