Fuel filler F12 | FerrariChat
Fuel filler F12
Discussion in 'F12/812' started by ferrarista550, Mar 1, 2021.
  1. ferrarista550
    ferrarista550 Karting
    Jan 6, 2011
    57
    Torrance, Calif.
    Mike Dwyer
    #1 ferrarista550, Mar 1, 2021
    To put gas in my F12, I have to pull the "foreskin" back of the gas nozzle so it won't click off . . .I made a foam donut to put on the nozzle & it works . . . Image Unavailable, Please Login How have you F 12 owners dealt with this?
    rob5819 likes this.
  2. Yellow355
    Yellow355 Karting
    Oct 4, 2006
    56
    Southern California
    Bruce Li
    Many McLarens have the same issue too, so this is a great device, much better than circumcising the nozzle.
    350MH83, TomatoMan and ferrarista550 like this.
  3. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    942
    San Diego
    Rob Barry
    I have the same problem with my 458 Spider. The first two years with the car I never had any problems with gas pumps then one day I couldn't get gas to flow unless I pulled the covering back on the nozzle. Now it's 50/50 if it works, even if I go to the same pump at the same station.
    Does your foam donut end up smelling like gas? Where do you store it in the car to make it convenient when you hit the gas station?
    Rob
  4. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
  5. ferrarista550
    Jan 6, 2011
    57
    Torrance, Calif.
    Mike Dwyer
    No gas smell . .I keep it in the trunk.
  6. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,281
    hilarious post!
    ferrarista550 likes this.
  7. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Sam
    Not hilarious in California. The gas pump will only work on my FF if you pull back rubber foreskin with two fingers on nozzle and hold it the whole time until full
    Sent from my SM-G975U using Tapatalk
  8. RDItalian
    RDItalian Rookie
    Jun 17, 2019
    19
    Nor. Cal - Sacramento
    Ryan
    First time I put gas in my F12 I felt like a complete idiot. I could just imagine what everyone at the gas station was thinking... look at this Jack a^! in the Ferrari can’t even put gas in it.
    I bought one of these $.99 electrical conduit screw pieces. Put it between the fuel fill and nozzle, then I keep it right inside the fuel door. Works like a charm.
    SVCalifornia likes this.
  9. rob5819
    Dec 12, 2017
    942
    San Diego
    Rob Barry
    Similar multi-year discussion in the 458 forums: https://www.ferrarichat.com/forum/threads/filling-up-the-458-with-gas.398989/. Someone else has gone with a grommet for the same purpose: https://www.fillernecksupply.com/1963-1976-mopar-b-body-fuel-tank-grommet-filler-neck-seal/?gclid=CjwKCAiAlb_fBRBHEiwAzMeEdovprEWPdvtQws9l-H0PMJ9zxRx43G5HOhXAY4FDjQVRfAs5ufbHkhoCWAYQAvD_BwE. I just wish I could figure out why I didn't have a problem for over two years and now I have a problem 50% of the time at the same station at the same pump. No doubt, CA gas pumps are stupid. Each of my cars requires different approach at the gas station.
    Rob
