Fuel Gauge Issue? Or something else ... | FerrariChat
Discussion in '360/430' started by roro, Aug 23, 2013.
  1. roro
    roro Formula Junior
    Aug 28, 2006
    843
    Houston, TX
    Ro
    Took out the F430 last night and had about 1/2 tank showing on the gauge. Drove it around 20 miles downtown. When I left, the gas tank was already blinking with one bar. So I took it to a gas station and tried putting fuel in. It only allowed me to put like $20 or so in the tank before the pump started to click.
    Continued to drive it home and still the gauge was blinking with one bar. It was late and didn't want to get stuck so I stopped at another gas station and it barely let me put a few bucks in there before clicking again, even saw some overflow.
    I got back in the car and same thing, blinking 1 bar ... close to home, I just took a chance and made it.
    Does this sound like a fuel gauge issue?
  2. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Maybe faulty fuel level sender...
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,528
    Charleston, SC
    Curt
    Agree, Fuel level sender sounds like culprit. You can always take the left drivers side engine trim panel off and tap on the tank to confirm full.. then remove and put back on the connector at the pump to verify connection. If still low/in-error the pump needs to come out and the fuel level sender replaced.
  4. roro
    roro Formula Junior
    Aug 28, 2006
    843
    Houston, TX
    Ro
    Thanks for the info. This is helpful. Is there a diagram that shows the engine trim panel? I'll try the manual.
  5. fstbiker
    fstbiker Formula Junior
    Jun 28, 2012
    510
    New Jersey
    use this link you will find the service manual
    All Ferraris
