Fuel gauge voltage regulator | FerrariChat
Discussion in 'Technical Q&A' started by raemin, Mar 16, 2025.
  1. raemin
    raemin Formula 3
    Jan 16, 2007
    2,337
    Lyon (FR)
    R. Emin
    I have a 400i, with a swinging fuel gauge. With precisely a tank 3/4 full, I've got the following readings on the gauge :
    1) 3/4 (Ignition off),
    2) below 3/4 (750rpm)
    3) full (above 2000rpm).
    That's a Veglia from 1982, presumably found on many Ferrari of that era. Is there any voltage regulator built into these units?
  2. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    #2 wmuno, Mar 16, 2025
    The Veglia analog fuel gauge has internal compensation for changes in battery voltage. See the attached photo. I suggest you remove the gauge and do a bench test using a fixed resistance and varying the positive voltage. The pointer might move when you brake or accelerate as the fuel shifts within the tank.
    afterburner and Qavion like this.
