Fuel Indicator | FerrariChat
Fuel Indicator
Discussion in '456/550/575' started by Cappo, Mar 4, 2018.
  1. Cappo
    Cappo Rookie
    Dec 15, 2010
    6
    Quantity indicates 3/4 when the tank is almost empty. Had new sending unit installed, and still indicates 3/4. Gauge will go to 0 when key is turned off.
    Any guru out there?
    HW
  2. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    710
    Toronto
    Ryan
    How do you know it’s almost empty? By the low fuel light or by how much you fill it with? I have always wondered how accurate the gauge/light is. My low fuel light comes on when the gauge shows 1/4 full, seems early to me, should be about 25 or so litres left at that point. When I fill it, the needle will max out at 7/8 full, it never goes 100% to the full mark. I always stop to fill when the light comes on just in case, and it usually takes about 70-80 litres which seems about right per the needle, just not sure why the light comes on so early.
  3. rviani
    rviani Karting
    Jun 22, 2005
    81
    NJ
    Ron Viani
    Your symptoms are consistent with the float for the sender hanging up on a baffle in the fuel tank. There is some history of this happening on 456's. Solution is to remove the sender and reach into the tank with a long screwdriver and simply push the baffle out of the way.
    Cappo likes this.
  4. Cappo
    Cappo Rookie
    Dec 15, 2010
    6
    That sounds like a fix
    HW
  5. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    Can I ask where you got the ‘new’ fuel sender unit? I need one for my 456
