Fuel Inertia Switch - Public Annoucement | FerrariChat
Discussion in '458 Italia/488/F8' started by skilly, Aug 18, 2024.
  1. skilly
    skilly Karting
    Mar 15, 2024
    236
    Bay2LA CA
    Matt
    #1 skilly, Aug 18, 2024
    Just thought I would help anyone who runs into this...lots of info on the 360/430 but nothing I could find on the 488/Pista/F8
    Driving the freeway home from Monterey Car Week last night I had the unfortunate event of hitting a rock on the freeway at speed - it was about the size of a baseball and couldnt avoid it by the time a saw it. It created no visible damage, but will need a respray under the front lip (which I had JUST done)....anyway.
    The car detected it as an emergency and cut the fuel off and threw the hazards on. Not fun. The fault was "Fuel Inertia Switch Activated". All cars have these to avoid an event where there is a real collision and the fuel pump is pumping fuel and creating a catastrophic event.
    I didnt have the service manual with me, and had never experienced this before. Went straight to the forum and could find the reset procedure but the location remained a mystery. For the 360/430 its under the drivers seat. In fact, everything I read said keep looking there. Turns out its not - LUCKILY, I had very good friends driving up with me and one close to home and found some on line literature.
    So for those that ever experience this -
    1. Engine off
    2. Go to the battery in the footwell
    3. disconnect with the quick connect
    4. reset location is on the right side of the battery box (hidden behind the carpet.(you will feel a ;click, like a GFCI plug resetting)
    5. reconnect the battery
    6. car should start.
    plug looks like this - and captured a pic of the battery box indicating the location.
  2. Mrpseudonym
    Mrpseudonym Formula Junior
    602
    Sydney, Australia
    Good to know, thanks for posting. Just to clarify; your step 3 is disconnect the battery?
  3. skilly
    skilly Karting
    Mar 15, 2024
    236
    Bay2LA CA
    Matt
    yeah, not sure if this is a safety precaution or part of the reset procedure, but it was easy to use the quick connect while I was in there. After I reset the switch and reconnected it started right up. Keep in mind this is a physical switch so no option to reset through disconnecting the battery or closing/locking and walking away etc will do the trick. its a GFI for the fuel line.
    It just happens that the rock I hit gave a nice smack (need to replace a cracked fender liner) against the cowl in the battery box area and must have read it as a collision. Super simple to reset....once you know where it is!
    mdrums likes this.
  4. skilly
    skilly Karting
    Mar 15, 2024
    236
    Bay2LA CA
    Matt
    page 63, and page 235 of the Owner' Manual. Other than pressing the switch itself, there are no instructions about disconnecting or reconnecting the battery, so the fault may clear after hard reset on the switch without it.
    Mrpseudonym and mdrums like this.
  5. BAK5150
    BAK5150 Rookie
    Aug 24, 2024
    24
    London
    Burhan
    That is correct. Just turn the car off, reset the switch and then turn on and everything should be fine. There should be no need for a battery disconnect
  6. skilly
    skilly Karting
    Mar 15, 2024
    236
    Bay2LA CA
    Matt
    agree. With instructions that I found here for some of the earlier cars, it had a battery disconnect and switch locations were different as well. It didnt take much for it to trigger and was surprised to not see anything on the forum specific to the 488/F8.
  7. BAK5150
    BAK5150 Rookie
    Aug 24, 2024
    24
    London
    Burhan
    Yes the switch does vary a bit from model to model. But for pretty much all of them battery disconnect isn't necessary. I've had quite a few cars come in with broken switch brackets tho and that of course causes issues.
