Fuel Injcetors | FerrariChat
Fuel Injcetors
Discussion in '308/328' started by YellowHorse, Jun 30, 2014.
  1. YellowHorse
    YellowHorse Rookie
    Jun 18, 2014
    6
    Huntington Beach
    Mike Murphy
    Does anyone have any experience with cleaning fuel injectors or do you always replace them ?
    Thanks Mike
  2. YellowHorse
    YellowHorse Rookie
    Jun 18, 2014
    6
    Huntington Beach
    Mike Murphy
    Thanks Mike
  3. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    There seems to be a consensus that the older steel injectors are better than the new brass ones. I've not had a problem with cleaning older steel injectors and/or cleaning - testing brass version.
  4. Alfer
    Alfer Formula 3
    1,360
    NH/the Netherlands
    Menno
    For cleaning you better bring them to a specialist who likely cleans them ultrasonic.
  5. Rifledriver
    37,108
    That's an opinion but hardly a consensus. I and most others in this business that stay in contact have no feeling of one being superior to the other.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The places here that do ultrasonic cleaning, specifically do not do mechanical injectors.
    The cost to replace them does not justify much effort cleaning the old ones.
  7. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    changed mine to brass years ago - absolutely no problems !
  8. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    Aside from cleaning the old injectors, the opening pressure will be questionable, and thus the flow rates. Even cleaned up, you would need to put them on an injector tester to be satisfied that they have consistent flow rates. Some say you need to test new injectors too, but I expect they would be closer.
    I installed new injectors in my 84 QV last winter rather than send off the old ones for ultrasonic cleaning. Even new, the opening pressures varied - I soaked them all in carb cleaner first to clean them up, and after that they seemed pretty consistent.
  9. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    Just the facts sir! I bought a 308 2Vi several years ago and after reading some posts here I decided to buy an injector tester from a MB website. There were 38K on the clock when I tested them and they all opened at the psi noted in the manual and the fan spray was perfect on all. The tester was less expensive than a set of injectors. just sayin! lost
  10. Rifledriver
    37,108
    CIS injectors were cheaply made and cheap to buy. Bosch never really intended them to be serviced. They were intended to be replaced much like spark plugs. It just happens that a few cars are still on the road that use them so the costs have gone up. Bosch isn't still making 300,000 per day.
  11. Rifledriver
    37,108
    I have had one of those at my disposal for over 30 years. I can, depending on my technique make almost any injector look good. Conversely I can make almost any injector look bad.
  12. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Injectors ~30-40 USD each...plenty low to replace. If you measure flow, just choose 8 real close (BigTex idea for me...just fine).
    I just replaced mine and was quite satisfied.
  13. YellowHorse
    YellowHorse Rookie
    Jun 18, 2014
    6
    Huntington Beach
    Mike Murphy
    Outstanding feedback one and all thank you so much. It would seem the idea of cleaning these and testing for proper spray doesn't play out very well. Sounds like its time for some new ones.if $240 solves the mystery I'm in was just afraid of giving up my old steel ones.time to move on.
  14. mwr4440
    57,977
    Bavaria, The 'Other' Germany
    Mark W.R.
    Keep the steel ones or sell.
    There are members here who will buy the old steel ones from you.
  15. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    Thanks alot! I was just about to say if he was going to chunk them then I would take them. Now you are telling him to sell them.
    Damn.
  16. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    Don't believe everything you read! Just sayin, Lost
    PS of coarse it's on the internet so it has to be true! Yuk, Yuk
  17. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    Don't listen to this guy. Every user here on FChat is a certified genius. The steel ones are junk. I'll dispose of them for you free of charge.
  18. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    A year ago I was going to replace all my steel injectors since I have my intake plenum off. But before I decided to buy the new ones I had my steel injectors tested and cleaned, it turned out that all my steel injectors are all good as in all have even spray patten so, I reused all of them and my car still running smooth.
  19. mwr4440
    57,977
    Mark W.R.
    And when he found out the truth you would have felt guilty and paid him something.
    Cannot screw a 3x8 Brother.
  20. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    Really? Tell that to the FChatter that tried to sell another FChatter steel injectors at $100 a piece when they can be bought from the used bins at parts sellers for $10.
  21. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    For sure don't take the truth for face value just throw your good injectors away and buy new ones!!! You will then make an idiot happy! peace, Lost
    PS After you throw those bad,bad steel injectors away and replace them you may find you have an ignition problem but don't test anything just keep replacing parts until the problem is solved, it's the american way !!!
  22. mwr4440
    57,977
    Mark W.R.
    I hope that guy got "The BOOT" and called out.
    I would have done it one way are another in a second.
    I have already "Dropped a Dime" on one here trying to rip off someone else. Actually, I was not the only one in one particular instance.
    Conversely, I will issue high praise to anyone doing a good deed for another here. Have doen that quite a few times.
  23. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,322
    There's a guy who appears on Ebay doing that pretty regularly. It would have some comedy value I suppose if it weren't for the case that because he keeps appearing it suggests people are buying the things... :(
  24. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    What are you talking about??? You must be uninformed. A 30 degree spray pattern replaced with a 45 degree spray pattern shouldn't have any effect at all! Just ask the guy on here that spouts fluid dynamics yet posted a thread asking how to solve a junior high algebra problem.
    Just send those old crappy steel injectors to me. ;)
  25. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    No, he didn't and it wasn't my place to do so. After he read this thread, I was corrected by my fellow FChatter. He was offered them for $125 a piece and then told by person that he was uninformed when he questioned the price. Nice guy, huh? High ranking FCA guy. Yet one of many reasons I'm not an FCA member.
    Yes, I have had several FChatters offer free stuff or help and I have returned the favor. This prick obviously wasn't one of them.
