Fuel Injector Cleaning | FerrariChat
Discussion in '348/355' started by bballto, Jun 18, 2015.
  1. bballto
    bballto Karting
    Mar 10, 2014
    155
    Anyone have their Injectors cleaned recently. Thoughts?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,624
    San Carlos, CA
    Mitchell Le
    #2 yelcab, Jun 18, 2015
    Waste of money !
    I have done 4 sets now. They all come back 1-2% better than before (that is rounding error), patterns did not change, and no noticeable improvement at all. I would say that unless you have a running problem, and you suspect injectors clogging or poor pattern, forget the cleaning. Spend that money someplace else.
  3. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    Great and often overlooked service item to either replace/upgrade or rebuild, especially if the upstream portions of the fuel system have all been serviced. The micro filters can collect and become restricted with fine sediments, as well as malfunctioning/drippy valves. O-rings can also degrade over time. With the relatively high duty cycle that the stock 348 pieces run at, there isn't a ton of headroom for degraded injector performance, especially in a modified car. I'd service every 7-10 years.
  4. Asta
    Asta Karting
    Mar 29, 2014
    83
    NYC
    Rob
    Throw in a bottle of Techron.
    ddg599 likes this.
  5. chas-3
    chas-3 Formula 3
    1,281
    Colorado
    Chuck
    I have had good results with BG 44K fuel system cleaner.
  6. fatbillybob
    Aug 10, 2002
    29,148
    socal
    For contrasting view, I send my FI's out every major for service. I want my cars to be 100% but I cam time every time too, flush brakes and coolant every year even with extended life coolants. IMO spray pattern is everything.
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,617
    The Brickyard
    The Bad Guy
    Five years back I sent out my injectors for testing and cleaning. Most of them where only a point or two off. One was a bit low, and another a little lower than all of them. After cleaning they all came back right on spec. In my opinion it helps the injectors last longer.
  8. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I sent mine off to Mr. Injector and they came back with a report that said they didn't need the cleaning. Increases were immaterial.
  9. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Agreed. Over the winter I had the injectors in my ///M3 track car cleaned. They weren't far off but the engine now idles very evenly and seems to run smoother. Doesn't cost a lot, so why not?
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    SoCal LA/OC/New Mexico
    Tim Dee
    Clean + blueprint them, no if ands or butts
    RC engineering, get the works done
  11. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I've typically sent injectors to RC but they were closed for the holiDaze when I needed the ///M3 injectors cleaned, so I sent those to Cruzin' Performance. Seems like they did a great job, the service seemed more personalized than RC recently, the turnaround was super-quick, and they were a couple of bucks cheaper per injector. I think I'll use them again. No affiliation with either place, just reporting my own experiences.
