Fuel Injector removal tool | FerrariChat
Discussion in '308/328' started by Rod, Oct 14, 2020.
  1. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Any one got a spare fuel injector removal tool that I can borrow/rent or a reasonably priced tool for sale?
    Any suggestions appreciated!
  2. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    For the 328, just pull using an oprn spanner and a wooden pivotpoint
    For the qv use an open 12mm ( or was it 14, forgot) and unscrew them completely with the bush
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
  4. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    I didn't want to break/damage any thing... With the circlip removed should the whole injector lift out?
  5. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
  6. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    thorn and Rod like this.
  7. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    Talking for the 328: yes
    No circlip on, at least, the early qv
    Rod likes this.
  8. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Rod likes this.
  9. yelcab
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    Nope,
    You screw that on to the injector and it provides a lip for you to pry it up using an appropriate size open ended wrench.
  10. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Quick disconnect for an air hose?
  11. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
  12. yelcab
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
  13. Du_Man
    320
    Dallas, Texas
    Derek
    true that
  14. Baltz1969
    Baltz1969 Karting
    Apr 24, 2017
    74
    Chula Vista, CA
    Jose Baltz
    I made my injector removal tool for my 81 2V. The tool was easy to make:
    4 inch length 1 inch aluminum pipe
    3 inch or longer M12 x 1.5 bolt
    M12 nut
    M12 washer with 1 inch circumference
    M12 x 1.5 connector (female/female)
    I made the connector by using two injector connectors from an 80s Mercedes which use the same Bosch injector. Using a small nut & bolt I secured them together.
    I got the injector connectors from a local auto wrecking yard.
    I got the nut & bolt from Napa.
  15. Baltz1969
    Baltz1969 Karting
    Apr 24, 2017
    74
    Chula Vista, CA
    Jose Baltz
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Rod likes this.
  16. Baltz1969
    Baltz1969 Karting
    Apr 24, 2017
    74
    Chula Vista, CA
    Jose Baltz
  17. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    Thanks for the kind words. I made several prototypes and finally came up with this version that worked the best. With the stubby ratcheting wrench the job is super quick and the tube is non marring so no scratches on the intake.
  18. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    With all respect
    If you pull out the injector from the bush like that you damage the rubber inset beyond repair.
    By far the best way to remove the injectors is by taking out the complete assembly use the injector as allen key and remove the injector complete with rubber bush from the bottom. After that you can remove the injector from the rubber
    Pulling the injectors up can be done with the 328 setup as this is different
  19. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Others would disagree with you on this. I think Birdman was one of the first to document his 308 fuel injector removal experience on this forum and chronicled his challenges using the method you describe. In post #3 of the following thread (https://www.ferrarichat.com/forum/threads/why-and-how-to-clean-your-fuel-injectors.197021/) he outlines the challenges which include the injector shearing off in the carrier. This is mainly an issue with the softer brass injectors but having serviced hundreds of CIS injectors for folks over the years I can tell you that the steel injectors frequently suffer from distortion when using this method especially if the carriers have never been removed from the manifold and a lot of force is required.
  20. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    You are absolutely correct in that. Shearing, esspecially with the brass rubbish is a concern.
    Maybe i had to elaborate a little on my main concern: if you pull them out from the top, you NEED to replace the rubbers. In my experience with servicing, this is rarely done as they are hard to find and expensive. BTw, i never broke a steel one but you have to prepare them a little with penetrating oil upfront.
  21. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Understood. st@ven thanks for the added perspective regarding the need to replace the rubber bushings with the screw in carriers when extracting the injector from above.
    Sent from my SM-G960U using FerrariChat.com mobile app
  22. Baltz1969
    Baltz1969 Karting
    Apr 24, 2017
    74
    Chula Vista, CA
    Jose Baltz
    In my case the rubber seals had pushed the injectors out of the carriers & the ones that didn’t the carriers striped when I tried to remove them with the injector. Since replacing all the seals and damaged carriers I have been able to remove the injectors & carriers as one pice.
