355 - Fuel Injectors (5.2) | Page 4 | FerrariChat
355 Fuel Injectors (5.2)
Discussion in '348/355' started by Qavion, Apr 5, 2022.
  1. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    And the Sunoco article you are referring to is for race fuel only and states not for pump gas
  2. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,821
    Lake Villa IL
    johnk... and Mark HT like this.
  3. 26street
    Jan 30, 2021
    473
    Mark k
    Please in the opening statement of the Sunoco article says “As a matter of fact, those statements only have some merit in the street gas world where 93 octane fuel is king and 87 is used by most. In the world of racing gasolines where higher octane choices abound, sharp engine builders and racers know they need to look beyond octane to find the right fuel.”
    This article is about how Sunoco formulates racing fuels for higher octanes and faster burn rate these type of fuels are used in racing and Aviation and contain additives to help with and make faster burning fuel this type of fuel is not found at the local stations
    We can go all day with this the average guy here does not buy those type of fuels and pump gas is what is in his and probably everyone else tank even yours
    Qavion likes this.
  4. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,821
    Lake Villa IL
    Sure if you like.
    Antiknock ability is _not_ substantially related to:-
    1. The flame speed of the conventionally ignited mixture, this should be evident from the similarities of the two reference hydrocarbons. Although flame speed does play a minor part, there are many other factors that are far more important. ( such as compression ratio, stoichiometry, combustion chamber shape, chemical structure of the fuel, presence of antiknock additives, number and position of spark plugs, turbulence etc.) Flame speed does not correlate with octane.
    http://www.factorypro.com/tech/gasoline.html
  5. Qavion
    Qavion F1 World Champ
    14,592
    Ian Riddell
    Thanks. I have a cheap pocket oscilloscope, but I don't think I have an attachment to couple with the leads. I imagine I would need some kind of inductive coupling.
  6. 26street
    Jan 30, 2021
    473
    Mark k
    There are ways on using the scope on the primary circuit side that will have a Image which mirrors the secondary Circuit ——- check google too see if anyone has info on checking this way I have done it in the pass but I was looking for a problem where I was losing power too the coils or pick up sensors
    I found a bad coil shorted out internally from vibrations of the engine which is not what you are having a problem with
    But if you are unsure of what you are looking at it might not help you
    having a shop or the right equipment to see secondary is really the way to check it
    Hope you find the problem
    Qavion likes this.
  7. Qavion
    14,592
    Ian Riddell
    Update: Just got my car back. After a spark plug change (eight) and a single fuel injector change, the engine is running very smoothly (and the gearbox rattle has gone). I don't know if the temperatures were rechecked. I may do that at a later date myself (I have a temperature gun).
    Why spark plugs with so few kilometers on them and almost no sign of problems would cause this rough running, I don't know.
    Anyway, thanks again for all the input.
    INTMD8 likes this.
  8. m.stojanovic
    m.stojanovic F1 Rookie
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    One possibility is fake NGK plugs but it is usually the Iridium ones that are faked. Otherwise, it is possible that the spark plugs also deteriorate over time as the oil and whatever slowly soaks into the ceramic insulator. This may be exacerbated by little use and frequent running at idle when the deposits on the plugs do not get a chance to be well burned-off.
    A few months ago, in my similarly like your 355 little used 348, I suddenly had slight uneven idle. After I initially started suspecting the injectors, coils, HT leads, I decided to first remove and inspect the spark plugs - one of them had a small piece of carbon lodged between the electrodes. I replace all of them as they were already ~8 years in the engine.
    Qavion likes this.
  9. Carmellini
    Carmellini Formula 3
    Jul 16, 2019
    1,013
    Not aware, please expand.
  10. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    Just Google
  11. Qavion
    14,592
    Ian Riddell
    Interesting. Hopefully not platinum ones, too. I bought some NGK Laser Platinum PMR8B's recently. The packaging looked official and had Made in Japan written on the box, but the package came from Hong Kong. They were a few dollars cheaper than local outlets, but not significantly.
  12. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,284
    CT
    John Kreskovsky
  13. Qavion
    14,592
    Ian Riddell
    Thanks, John. Sounds like just what everyone needs. Analysing the waveforms seems relatively easy following this video. I spent an hour or two without success, though, trying to find an equivalent tool to the, no doubt, very expensive SnapOn "Modis" for amateurs.
  14. 26street
    Jan 30, 2021
    473
    Mark k
    Yes that was a great video and for the cars we play with should be something to use that’s why I suggested and yes snap-on Modis is a very good tool but costly for hobbies
    I have 2 scopes that I use regularly one is a old LS2000 which I had for almost 30years and it still works great easy to use and does everything I need and the other is a laptop base unit “TIE PIE engineering scope” both work great on automotive application and are not that expensive the LS can be pick up from eBay for around $150 “usd” the tiepie software is free and the cheapest interface is around $500 “usd” but either way any one have with the right hook ups can save you time and money
    This type of diagnostics is be coming a lost art it’s a shame the newer techs don’t learn it and older techs who do are harder to find
    Qavion likes this.
  15. Qavion
    14,592
    Ian Riddell
    The LS2000 is a "Snap-On Sun LS2000 Automotive Oscilloscope Diagnostic Scanner"?
    eBay and Amazon seem to be showing nil stock at the moment.
  16. 26street
    Jan 30, 2021
    473
    Mark k
    Not a scanner just scope
    I have the mt2500 scanner too might be looking to sale it soon
    Qavion likes this.
