Fuel Injectors (again) | Page 2 | FerrariChat
Discussion in '308/328' started by topley, Apr 16, 2024.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    The After sure looks great. What’s the name of the shop where you took it to?
  2. topley
    topley Karting
    May 10, 2022
    91
    Los Angeles
    Jay Barton
    miketuason likes this.
  3. TheMayor
    107,095
    Vegas baby
    I did that.
    slfan and smg2 like this.
  4. topley
    topley Karting
    May 10, 2022
    91
    Los Angeles
    Jay Barton
    One more thing to note... now that I see how bad they really were I'm AMAZED I passed CA Smog just 2 months ago....
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    That's because once it's running all that matters is that they are open since it's CSI. Doesn't matter what pressure they open, or if they leak.
    Be interesting to see it it solves your warm start problem.
  6. Rifledriver
    37,288
    #31 Rifledriver, Apr 22, 2024
    Leaking is a real problem when you turn it off. Thats were the warm start problem came from. Residual pressure goes away and the fuel in the lines vaporizes. Since fuel injection is a hydraulic system like brakes it now has air in the lines and has difficulty making enough pressure to open the injectors. Takes a lot of cranking to make that happen.
  7. SeattleM5
    SeattleM5 Formula 3
    1,265
    Kirkland, Washington
    Ettore Palazzo
    #32 SeattleM5, Apr 23, 2024
    It's too bad that they didn't check flow rates pre/post service. As mentioned earlier in this thread, the differing injector opening pressures will cause different flow rates which is not ideal. I have confirmed this on my test bench and it has been documented here in the past as well: Flow Testing Results of OEM CIS Injectors | FerrariChat
    One thing that I'm perplexed by is the significant change in opening pressures that was documented pre/post injector service. In my experience cleaning/servicing injectors can definitely correct leaky injectors and poor spray pattern but I have never seen this dramatic of a change in opening pressures pre/post service. The opening pressure of a CIS injector is determined by the internal spring which exerts a force on the pintle keeping it closed until fuel pressure overcomes the spring pressure. The internal spring is fixed and can not be adjusted so I'm having a hard time understanding these wide swings in opening pressures pre/post servicing. The increase in opening pressure after correction of leaks makes some sense but I've never seen a 35 psi/2.4 bar increase as was the case with injector #8. I'm especially scratching my head over injector #1 which did not have any leaks pre service and saw a 9 psi/0.6 bar increase in opening pressure.
    Finally, I'm glad to see that there is agreement that leaky injectors can cause hot start problems on CIS cars. While in my experience a failed fuel accumulator seems to be the most common cause, I have seen leaky injectors be the culprit on several CIS cars that I have worked on noting that there has been debate on Fchat before regarding this. See post #14-20: 308 QV hot starting problem, new | FerrariChat
  8. SeattleM5
    SeattleM5 Formula 3
    1,265
    Ettore Palazzo
    One additional thing that I would add for the originator of this thread or anyone else that is planning on replacing/servicing their CIS injectors. From time to time I will work on a set of injectors or put together a perfectly balanced set of injectors (equal opening pressures) and after they get installed the car runs a bit worse. It's almost always the case in this situation that an AFR adjustment is needed. It is usually on cars that have their original fuel injectors in place and have had mixture screw adjustments performed over the years attempting to compensate for progressively abnormal performance of the fuel system components. The same is true for a rebuilt fuel distributor after the flows are dialed in evenly. Especially on those with significant flow variances pre rebuild. Hope this helps!
    ggjjr and slfan like this.
