fuel injectors | FerrariChat
fuel injectors
Discussion in 'Mondial' started by ozmondy, Jun 16, 2015.
  1. ozmondy
    ozmondy Formula Junior
    Oct 30, 2013
    307
    N.T, Australia
    Peter
    heya folks
    been awhile as I have been flat out rebuilding my QV
    I suspected a head gasket and it was but from a cracked head stud not a failure of cooling port or gasket. It basically lost tension in the bottom corner and blew the gasket.
    It is back in and running to my relief but I have found that my oversight of not replacing the seals around the injectors has come back to bite me and I have 2 leaking causing a vacuum leak and rough idle as well as a bit of "pig rooting" in top gear.
    Can anyone point me in the right direction of a replacement nozzle and seals.
    I have heard that a Mercedes 450 SL nozzle is the same but does that apply to the seal as well.
    Any help would be greatly appreciated.
    Peter
  2. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #2 soucorp, Jun 16, 2015
  3. ozmondy
    Oct 30, 2013
    307
    N.T, Australia
    Peter
    Hey thanks for that reply
    I did find Birdmans thread but found conflicting reports on the seal.
    Superformance list 2 different seals
    Fuel System Parts for Ferrari Mondial - Superformance
    Really don't want to pull it down and have to wait for parts.
    Might just order 8 of each
    Peter
  4. 308mon
    308mon Karting
    Oct 5, 2014
    169
    You want both the "O-ring" and the "rubber". P/N 113570 and P/N 114661
  5. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #5 soucorp, Jun 16, 2015
    I see what you mean Peter, yes I would agree to go with Superformance for the seals, but I only see 1 offered.
    You might need o rings as well ???
  6. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    I found that the 85-89 MB 190e has the exact same injectors. I pulled a few from a local pick-n-pull. Exact same part number. The only difference is a MB logo stamped on below the part number.
    I did not check the seals, so I can't help there. I haven't cleaned/used the pick-n-pull injectors yet. That's a project for later this summer
    sid
  7. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
  8. ozmondy
    Oct 30, 2013
    307
    N.T, Australia
    Peter
  9. ozmondy
    Oct 30, 2013
    307
    N.T, Australia
    Peter
    PS
    Bell you have the earlier style set up with screw in bushes not the push in type with the O ring at top groove.
    your engine must be 1847 or less.
    Mine is number 2470 so has the later style as per thread I posted.
    Peter
  10. mulo rampante
    mulo rampante Formula Junior
    May 31, 2011
    997
    Terra Incognita
    Charles
    SidTX is spot-on: Bosch 0437502047 as used in the MB 190e is what's presently in my car.
    You may find that the price of the injectors is similar to having them cleaned. I paid USD 30 each for these new from Bosch (manufactured in Europe, I don't remember where). I see no merit in cleaning old ones if new can be obtained so cheaply. There are both brass and steel variants, with steel being OE in my car. I don't believe the material makes any difference.
    I think the O-rings cross to a Rolls Royce part. Bosch p/n 3430210606 according to my notes.
    For the other rubber piece, I believe Ferrari or one of the aftermarket suppliers is the only option. Don't think these cross to anything else.
  11. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    #12 sidtx, Jun 18, 2015
    However, I felt the need to pull some from a junkyard MB 190e to, ahem, "justify" to my wife, the purchase of an injector test rig.
    In all seriousness, I bought the rig so that I could test the injectors on her 85 MB W123 (300D). And, since the rig had an optional adapter for the gas injectors, I pulled a few of those from the junkyard as test (play) items. I'll have to say, that for the MB W123 injectors (which are rebuildable, adjustable, and expensive), the test rig worked like a charm, and was more than worth the purchase price.
    And anyway, who doesn't like playing with tools (toys) that can spew fuel at over 100PSI?
    Sid
  12. FCnew
    FCnew Formula Junior
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    Where is the "Like" button.
  13. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    #14 350HPMondial, Jun 19, 2015
    Sid,
    By fuel , you meant Diesel, for the test fluid in both Gas and Diesel injector tests.
    I hope.
    I have an injector test rig also,,,, I'm going to test my 308 injectors with diesel.
    I feel, Gasoline is just too dangerous?
    Or, I might use lacquer thinner....??
    Opinions, feedback needed.
    Thanks all.
    Edwardo
    Stop, drop and roll...
  14. FCnew
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    #15 FCnew, Jun 19, 2015
  15. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    Diesel is used for both the Gasoline injector test and the Diesel injector test.
    The rig will vaporize gasoline, which when mixing with air, becomes waaaay to explosive.
    While conceptually, a flame-thrower might be fun, the possibility of explosion is just tooo great for me to play with. Fuel-Air explosive anyone? Not me.
    This is where I bought my injector rig. nice, small and compact, and bolts down to a workbench
    Sid
  16. 350HPMondial
    5,325
    Edwardo
    Thanks all,, I picked up a Gallon of diesel yesterday.
    Very informative thread.
    Edwardo
  17. Bell Bloke
    Dec 6, 2012
    1,839
    Keroscene, that's very safe and a good sustitute for gas, diesel is a bit thick
  18. ozmondy
    Oct 30, 2013
    307
    N.T, Australia
    Peter
    Heya folks
    just a brief update on the injector replacement.
    I pulled the nozzles out of the injector bush easily and then the bigger rubber donut O' ring.
    Pulled out the circlips that hold the bush down and that's where it all stalled...there is no way known that you can pull that bush out without destroying it.
    Mine were a black plastic and I dicked around for nearly 2 hours on the one bush before giving it a biiiiiiiig miss and pulled off the intake manifolds in around an hour and knocked em out from the bottomd with a 10mm 3/8 drive tube socket.
    I have just ordered new bushes with O rings from Geert Jan off his 400 site
  19. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Did you take any pictures of the process? I'm thinking I may end up doing the same with my car while it's apart. Very old rubber in an important place.
  20. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    If Ferrari wrote Service Bulletins 30 years after a model was new, this would be on the list ;)
  21. ozmondy
    Oct 30, 2013
    307
    N.T, Australia
    Peter
    Couldn't agree more Steve
