Fuel leak from "mystery" part | FerrariChat
Discussion in 'Technical Q&A' started by sguinn, Jan 9, 2006.
  1. sguinn
    sguinn Karting
    Nov 12, 2005
    151
    Arkansas
    Spencer Guinn
    #1 sguinn, Jan 9, 2006
    Day three into the joy of Ferrari ownership... When my "new" '79 308 GTS arrived Saturday I filled up the gas tank. After driving around for a few hours, I parked in the garage and I smelled gas coming from the right side of the engine bay. It slowly improved over the weekend (and several more hours of driving), and I never saw any leaks or source. This morning it was almost gone, but the tanks were also almost empty. Still concerned, I ran the fuel pump while I traced out the lines, but did not find any leaks or "sweating" at the connections. All of the lines have been changed out during prior service.
    I filled the tanks again on my way home this evening, and when I parked in the garage the smell had returned. This time I found a few drops of fuel coming down from the front part of the right rear wheel well. I put it up on jack stands, removed the wheel well, and found that one of the connectors into this "mystery" part was broken. This line comes out of the top of the right fuel tank. What is this part? The only service manual I have is the 308 GT4 one, and the fuel diagram does not have this listed. In the photos, the part is at the 12:00 position. The bottom photos show were the connector has broken off. All of the hoses were in good condition.
  2. k wright
    k wright F1 Rookie
    2,544
    North East TN
    Kent Wright
    Looks like an evaporative collection canister. Is there any charcoal in it? Mail this to Daniel Pass (Ricambi America) and he will email you with the price and send you the part immediately.
    From what is visible of the car, it looks great.
    ken
  3. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Congratulations on your new beast mate!! Isnt that your carbon canister?? Im sure you can get a good boilermaker to solder/weld that back on for you. The carbon canister contains charcoal whichs absorbs fuel vapour fumes. Hope this helped? If it is the carbon canister on these 308's????? LOL :) Cheers
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    It's not a charcoal cannister. It's a vapor separator, that collects fuel vapor, alllows them to condense back to liquid form and return to the tank.
    Brian
  5. Steve Magnusson
    26,785
    It's good to hear that the rubber lines were in good shape (usually these are dry-rotted and you get the same symptoms that you're having with some fuel sloshing out when full). There's an early US 308GT4 fuel evaporation control system shown on pages O14-O16 of the 308GT4 WSM and the system for a '79 US is the same as that shown on page 85 of the 150/78 308GTB/S US OM (download it from the Owners Site or Steve Jenkins' Ferrari site, etc.).
    My reason for posting is to ask if the (open) tube on the top of your fuel liquid/vapor separator is connected to anything or not? You don't have to have a full blown working "US" type system, but if you're going to run a simple system that's just vented to atmosphere IMO it should still be reasonably "sealed" on the unwetted top end (e.g., it would be better to cap off the top of the liquid/vapor separator -- after you get a new one -- and run some type of vented fill cap). Anyway, please describe what you have vs. the system shown on 150/78 page 85 system if you'd like some suggestions.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,556
    San Carlos, CA
    Mitchell Le
    Brian is right.
  7. sguinn
    sguinn Karting
    Nov 12, 2005
    151
    Arkansas
    Spencer Guinn
    Thanks for your input. The top was not connected to anything when I checked it originally. The tube that broke off was off of the bottom. All of the other emissions equipment had been removed by the previous owner. I'll have to wait until I'm home this evening to look at those diagrams and compare.
    Spence
  8. 308 GTB
    308 GTB F1 World Champ
    11,718
    New Jersey
    Barry Wolinsky
    #8 308 GTB, Jan 10, 2006
    The vapor separator, as Brian said. #22 (Part #109843) on this diagram from the parts manual. Check with Daniel at Ricambi America.
  9. BigTex
    79,380
    Houston, Texas
    Bubba
    That diagram doesn't show the charcoal filter can.
    It was added in 1977, IIRC, along with the opening solenoid and the driver's seat micro switch.....
    Wouldn' t the solenoid be in the line venting this seperator you are talking about?
    Dumping that fuel vapor laden air to atmosphere is asking for a visit from Mr. Sparky!!!
    Without the solenoid I'd vent it via fuel line into the charcoal filter can.
    Anyone have the complete 1979 diagram to show him what is missing?
  10. Steve Magnusson
    26,785
    That's the correct figure for the '78-'79 US 308GTB/S -- the charcoal canister is item 18. It shows the early 308 style canister shape -- the later '78-'79 charcoal canister is shaped a little differently, but they didn't bother updating the drawing precisely (this was "before CAD").
    The difficulty with just connecting the open line to a charcoal canister and then letting the charcoal canister vent to atmosphere is that the charcoal will just saturate with vapors so it would still just look like an "open" line dumping out into the atmosphere. To run a closed system you need to have a way for the fuel vapors to be ingested back into the engine intake (without putting too big a vacuum and imploding the fuel tanks).
  11. BigTex
    79,380
    Houston, Texas
    Bubba
    "Filter Vapor Combustible"
    Yep, that's it! Thanks!
  12. 308 GTB
    11,718
    New Jersey
    Barry Wolinsky
    Hi Bubba,
    That's from a 1978 parts catalog. The charcoal canister is the #18 & 21 combination.
    My 1976 GTB has the driver's seat switch too, disconnected in my car.
    Barry
  13. BigTex
    79,380
    Houston, Texas
    Bubba
    Got it.......so only when "at rest" (seat empty) is the filter canister on line?
    The rest of the time it's routed back to the intake??
    *remembering*
    Oh yea, if it isn't jumpered the fuel pump turns off when you get out....(???)
  14. 308 GTB
    11,718
    New Jersey
    Barry Wolinsky
    I have to rely on my high school and college Latin to read these parts manuals. Thank you, too, Steve. I think Spence will have an easy time of it when he gets home and checks this thread.
    Barry
  15. sguinn
    sguinn Karting
    Nov 12, 2005
    151
    Arkansas
    Spencer Guinn
    Thanks to everyone for their help. It is definitely #22 that was leaking. The tube #28 is missing, and I can't find the canister #18 to which it leads. When I replace #22, what about the open hole on top where tube #18 attaches?
    Spence
  16. Steve Magnusson
    26,785
    #16 Steve Magnusson, Jan 10, 2006
    If you can get item 16 (the check valve) and the canister (item 18), you could hook those back up correctly using hoses 28, 17, 21, 51, and 52 (it isn't absolutely necessary to get the little blower motor item 56 -- you could just plug that port on canister 18 where tube 54 connects) -- check with Ricambi America, etc.. Otherwise, as I said earlier, I think it would be best to plug the top of the separator and find a vented filler cap (if such a thing exists).
    Since this stuff has been removed what do you presently have connected to the metal vacuum tubes on the intake manifolds where hoses 51 and 52 normally connect? Are they just capped off?
    The photo below shows the charcoal canister item 18 on my ex-78 US 308GTS to the right of the coolant expansion tank (i.e., yours must be missing if you can't easily find it):
  17. sguinn
    sguinn Karting
    Nov 12, 2005
    151
    Arkansas
    Spencer Guinn
    That charcoal canister is not present on mine. Do I need to reinstall that other equipment, or is there a safe way to change this? On the UK Owners site diagrams none of these are present either.
    Spence
  18. Steve Magnusson
    26,785
    Yes, I had noted that the "fuel pump and pipes" diagram on the Owners Site given for the USA 77-80 308GTB/S was/is not quite right. The page that Barry posted matches my print copy of the 161/78 SPC (and my ex-'78 US version 308).
    With regard to how necessary it is to reinstall this stuff, from a minimum safety viewpoint, I think you absolutely need to have a system that won't allow liquid fuel to directly run out if the car goes upside-down. I had a look at some of the Euro set-ups at the Owners Site that don't have any type of fuel evaporation control system (nor a fuel separator ;)) so you might be able to duplicate one of those configurations less expensively if the US parts 16 and 18 are no longer available.
  19. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    FYI we have 6 new 109843 vapor separators in stock.
    Brian
    T.Rutlands/Maranello Auto Parts
  20. sguinn
    sguinn Karting
    Nov 12, 2005
    151
    Arkansas
    Spencer Guinn
    Thanks. I found a "good" used one and installed it today. The fuel odor is gone now. I also took this as a chance to replace all four of those hoses that come off of the right fuel tank. All of the others in the car had previously been changed out.
    Spence
