Fuel Level sending sensor 78 Ferrari 308 | FerrariChat
Discussion in 'Technical Q&A' started by Lefthand43, Jun 17, 2017.
  1. Lefthand43
    Lefthand43 Rookie
    Aug 27, 2014
    24
    Maumee, Ohio 43537
    Fritz Kunz
    Sensor works normal from full to half tank than goes erratic bouncing from empty to half full. Can sensor be rebuilt? Thought I saw somewhere that early Fiat has same sending unit as Ferrari, can anyone send info and part numbers?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    They all do that sir
    Seriously - the light begins to come on (first flicker) with about 100 miles left and then thinks about going solid with about 50 left - if that's what you see then that is so normal that you'll need to find a better excuse to tear down the car !
  3. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,290
    Ian Riddell
    Were you looking for a cheap solution, or just a solution?
    If the latter, why not have a custom sender made up which dampens the indication (i.e. not electronically, but physically). Isspro from Portland, Oregon made up a sender for my Lotus Esprit. I had to find all the specs, though, such as bolt pattern, height of tank, approximate length of sender, resistance at full and empty, etc. The custom sender has a float inside a cylindrical chamber with a bleed port. Fuel flows into the chamber relatively slowly, so there are no rapid movements of levels due to fuel sloshing about in the tank. I'm assuming this is the cause of the 308's indication fluctuations?
    You can buy electronic damping solutions for some cars, but I haven't heard so many good reports about them and you may have rewire the car... not good if you want to return the car to original.
  4. greyboxer
    Dec 8, 2004
    12,665
    South East
    Jimmie
  5. ferrarioldman
    ferrarioldman Formula 3 Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
  6. Lefthand43
    Lefthand43 Rookie
    Aug 27, 2014
    24
    Maumee, Ohio 43537
    Fritz Kunz
    Pulled out the fuel sending unit on my 78 308.The coiled wire resistor had broken wires in the middle of the curved resistor. Bought a fiat sending unit 124 FI part number 4432195 from Allisons automotive a so. Cal. fiat parts dealer ($70.00) and swapped out the complete resistor housing with the broken Ferrari housing. Identical match and resodered everything.
  7. Michael Foreman
    Michael Foreman Rookie
    Jul 11, 2017
    17
    Northeast PA
    Michael Foreman
    Having the sending unit diagnosed is your first step. Modifications can be taken a few different directions for either a slower moving gauge or a more accurate one
