Fuel lines from pump and cover - advice on replacement | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by MathKernelKing, Sep 1, 2016.
  1. MathKernelKing
    MathKernelKing Karting
    Jun 16, 2015
    76
    San Francisco, CA
    Noah
    #1 MathKernelKing, Sep 1, 2016
    I would like to replace my fuel lines coming out of my fuel pumps. Has anyone done this, and do they have any advice? These parts are not available anywhere.
    Specifically, the parts I need come from 400i manual Table 9 - Fuel Tanks, Pumps, Lines
    46. 115605 - fuel line (2)*
    47. 113681 - fuel line (2)*
    48. 111644 - banjo fitting (2)*
    50. 116778 - fuel line (2)*
    73. 105078 - fuel pump cover driver's side (1)*
    Has anyone ever replaced their fuel pump cover as well?
  2. Part Time
    Part Time Formula Junior
    500
    Port St. Lucie, Fl
    Gary Shore
    Hello, Noah.....
    about a year or so ago I replaced both fuel pumps and the hose from the center tank fittings to the pumps. I brought an original sample hose to my local NAPA store and they matched it up to the fuel hose used on portable fuel tanks and those you see mounted in the back of pickup trucks. I think it was from Goodyear and they showed me the specs which stated it was approved for all types of fuel and various other chemicals.
    Sorry but can't help with the other braided hoses, except that there should be a local business that makes hoses for marine, heavy equipment or performance, just have them copy yours.
    The cover plate on the bottom is the same piece of sheet metal for both sides, just bent in the opposite way, Home Depot has the aluminum, use the one you have to trace onto paper, cut it out, and bend it the other way, drill holes.....it's there to protect the pump/accumulator assy...just in case you run over a squirrel he won't hit his head on the pump.
    Gary
    PS: change the fuel return lines from the steel lines thru into the trunk and back to the tanks while you are under there, standard fuel line from NAPA.
  3. fcf
    fcf Rookie
    Jan 30, 2015
    35
    Germany
    Frank
  4. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Use the translation feature. It works wonderfully. Thank you Frank. Jq.
  5. bjwhite
    bjwhite F1 Rookie
    4,803
    Seattle, WA
    Brian White
    Hello Frank. I would love to see your blog, but it seems the site no longer resolves. Still have the content?
    Schumi likes this.
